I have an ISO which was created from a NTSC DVD recorded from a NTSC VHS. I don't have the VHS. Vidcoder does show that is has CC608 in it but after encoding I don't see the CC. The mediainfo shows the format as ASS. I'm not sure if CC exists in it or not.. maybe were not included in the recording, I just don't know. I wonder if there is another way/tool to confirm if the CC really exists or not?
Results 1 to 12 of 12
EIA 608 CCs are stored in the video's MPEG user data. Because of this, CCs are not preserved when video is re-encoded. Some editing software also strips them, even in sections where the video is not re-encoded.
Ignore list: hello_hello, tried, TechLord, Snoopy329 -
Ass? Let's see, MP4 doesn't take ASS, in fact as far as I'm aware only MKV can mux ASS internally... so if we assume you created an MKV, MKV DOESN'T take 608 captions, so in order to keep them VidCoder would have to convert them to something else. ASS has positions where SRT doesn't so that makes sense...
MKV
Am I right? -
MKV doesn't support tracks within tracks, any MKV compliant remuxer would remove the captions from the video before muxing it into an mkv.
Have you ever actually seen an mkv with captions in it? Really I'd be interested to know what created it. MKV has NO official support of 608 captions at all, that's a sore point for some people.
MP4 tends to store its captions in it's own track, since MPC-HC can't read them that way and VLC only recently gained that ability it's doubtful many non-apple re-encoders would bother storing them that way, add to that the fact that they tend to alter the frame rate making storing them in the video impossible and you're left with very little chance of retaining the captions in their input format. -
Yes the encode was mkv. I just tried CCExtractor, though I never used it before so not sure about the right option I must use. It tried some formats and it did create a file for "dvdraw". Does it mean the source has CC?
When I play the VOB file ( ISO extract ), VLC shows Closed Caption 1-4 in the subtitle menu. But no matter what option I select, it won't show any CC. The mediainfo doesn't show any info about CC though.
ThanksLast edited by vidblue; 28th Feb 2017 at 13:38. Reason: Correct info
The fact that the MKV header is missing some information doesn't mean that there are no closed captions present. I just used VideoReDo TV Suite to create an MKV (MPEG-2 video and AC3 audio) from a DVD containing a TV broadcast which included closed captions. MediaInfo didn't reveal that there are EIA-608 captions present but they were still there. All I had to do was use CCExtractor GUI on the MKV file to retrieve them. On the other hand, when I tried MakeMKV on the same DVD, it stripped the closed captions.
I download video from OTA broadcast networks here in the USA sometimes to catch up on a missed episode. Some MP4s have EIA 608 and even EIA 708 closed captions and some don't. The timing doesn't seem to be wrong when I watch them.
HTML Code:General Complete name : K:\Grimm\El Cuegle.mp4 Format : MPEG-4 Format profile : Base Media Codec ID : isom File size : 560 MiB Duration : 43mn 16s Overall bit rate : 1 808 Kbps Movie name : GRIMM Law rating : TV-14 (V) Writing application : Lavf57.66.101 Video ID : 1 Format : AVC Format/Info : Advanced Video Codec Format profile : High@L3.1 Format settings, CABAC : Yes Format settings, ReFrames : 1 frame Format settings, GOP : M=1, N=48 Codec ID : avc1 Codec ID/Info : Advanced Video Coding Duration : 43mn 16s Bit rate : 1 696 Kbps Width : 1 280 pixels Height : 720 pixels Display aspect ratio : 16:9 Frame rate mode : Variable Frame rate : 23.976 fps Minimum frame rate : 23.810 fps Maximum frame rate : 24.390 fps Color space : YUV Chroma subsampling : 4:2:0 Bit depth : 8 bits Scan type : Progressive Bits/(Pixel*Frame) : 0.077 Stream size : 528 MiB (94%) Writing library : x264 core 120 Encoding settings : cabac=1 / ref=1 / deblock=1:0:0 / analyse=0x3:0x113 / me=hex / subme=6 / psy=1 / psy_rd=1.00:0.00 / mixed_ref=0 / me_range=16 / chroma_me=0 / trellis=1 / 8x8dct=1 / cqm=0 / deadzone=21,11 / fast_pskip=1 / chroma_qp_offset=-2 / threads=8 / sliced_threads=0 / nr=0 / decimate=1 / interlaced=0 / bluray_compat=0 / constrained_intra=0 / bframes=0 / weightp=2 / keyint=48 / keyint_min=25 / scenecut=0 / intra_refresh=0 / rc=abr / mbtree=0 / bitrate=1696 / ratetol=1.0 / qcomp=0.60 / qpmin=10 / qpmax=51 / qpstep=4 / ip_ratio=1.40 / aq=1:1.00 Audio ID : 2 Format : AAC Format/Info : Advanced Audio Codec Format profile : LC Codec ID : 40 Duration : 43mn 16s Bit rate mode : Constant Bit rate : 96.0 Kbps Channel(s) : 2 channels Channel positions : Front: L R Sampling rate : 44.1 KHz Compression mode : Lossy Stream size : 29.7 MiB (5%) Text #1 ID : 1-CC1 Format : EIA-608 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 43mn 16s Bit rate mode : Constant Stream size : 0.00 Byte (0%) Encoded stream size : 0.00 Byte (0%) Text #2 ID : 1-CC4 Format : EIA-608 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 43mn 16s Bit rate mode : Constant Stream size : 0.00 Byte (0%) Encoded stream size : 0.00 Byte (0%) Text #3 ID : 1-1 Format : EIA-708 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 43mn 16s Bit rate mode : Constant Stream size : 0.00 Byte (0%) Encoded stream size : 0.00 Byte (0%) Text #4 ID : 1-3 Format : EIA-708 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 43mn 16s Bit rate mode : Constant Stream size : 0.00 Byte (0%) Encoded stream size : 0.00 Byte (0%) Text #5 ID : 1-4 Format : EIA-708 Muxing mode : SCTE 128 / DTVCC Transport Muxing mode, more info : Muxed in Video #1 Duration : 43mn 16s Bit rate mode : Constant Stream size : 0.00 Byte (0%) Encoded stream size : 0.00 Byte (0%)
If nothing plays them they're kind of useless, that's what standards are for and currently there is no official method of storing 608 captions in an MKV. Theoretically you can put pretty much anything in either an MP4, an MKV, or even the user data in the MPEG2 stream, but just because you can doesn't mean anything.
You're trivialising a sore spot for some people. If you know of official standards for having 608 captions in mkvs then I'd love to go around to all the players and muxers bug trackers to spread the word, I've already managed to get VLC playing Final Cut Pro mp4 captions, but just saying they're in there is meaningless. -
...except apparently to the OP in this thread. He wants to know if CCs are present in his MKV.
I just demonstrated that it is possible that a video in a MKV might have CCs. Assuming the DVD video was not re-encoded and they were not simply stripped for some other reason, CCExtractor GUI will normally retrieve them
[Edit] CCs can be there and officially supported and still not play. Some software players don't play closed captions at all and some will only play CCs for DVD video or ts files.
I use CCs fairly often, and find the poor support for them to be disappointing, so I'm not trivializing the situation. I'm addressing the question at hand.
[Edit 2] Just for fun, I tried playing the MKV with intact closed captions using VLC. VLC displayed them.Last edited by usually_quiet; 28th Feb 2017 at 14:37. Reason: clarity
So how do I confirm the existence or extract CC using CCExtractor with right selection off the ISO? The activity log of CCExtractor shows this -
Code:File seems to be an elementary stream, enabling ES mode Found PACK header in ES data. Probably wrong stream mode! Skip forward to the next Sequence or GOP start.
I think I used the default settings on the MKV file.
CCExtractor GUI produces an empty file if there are no closed captions present.
I think I have seen that once or twice. CCs are flagged but the fields are empty.
I haven't seen that error message before. I don't know what it means.Last edited by usually_quiet; 28th Feb 2017 at 15:02.
Does anyone know how to extract subtitles from .ts?
By ALUOp in forum DVB / IPTVReplies: 48Last Post: 27th Jul 2022, 00:39 -
Can't extract all subtitles
By slycordinator in forum SubtitleReplies: 8Last Post: 18th Mar 2016, 01:50 -
Cant extract subs?
By max_cady in forum SubtitleReplies: 7Last Post: 10th Sep 2015, 01:34 -
Extract subtitles from avi
By Snowcrystal in forum SubtitleReplies: 11Last Post: 16th Feb 2014, 19:08 -
How To Extract One Video From Three
By Treeant34 in forum Newbie / General discussionsReplies: 6Last Post: 3rd Apr 2012, 11:48
