Can anyone help? I have a few dvd's with the movie spanning two dvd's (LOTR extended, The Godfarher part 2, The Triangle). I want to rip and merge the movie to one file. Any help would be greatly appreciated. Thanks in advance.
Dave
Results 1 to 11 of 11
MakeMKV is the free alternative to MakeMKV
http://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 -
MKVToolNix GUI, drag and drop the first file on and it should activate the tab, drag and drop the second file and unless you've changed some settings it should ask what to do with it, make sure to ask to append the file and from there you can just start muxing.
I am having issues with toolnix. I have uninstalled and re-installed the program and I keep getting "the video file cannot be appended onto itself." How can I fix this?
Merging sources
By Akai-Shuichi in forum RestorationReplies: 2Last Post: 22nd Nov 2016, 19:12 -
merging clips
By Phalter in forum Video ConversionReplies: 25Last Post: 25th Feb 2016, 10:09 -
Merging different bitrates
By carlmart in forum Video ConversionReplies: 7Last Post: 15th Mar 2013, 09:01 -
Video merging
By Videographer in forum EditingReplies: 8Last Post: 9th Aug 2012, 11:12 -
Merging files
By drtbray in forum EditingReplies: 12Last Post: 13th Apr 2012, 16:08
