    Sep 2008
    Spain
    https://www.amazon.es/Tarjeta-memoria-SanDisk-Extreme-UHS-I/dp/B00NP63XGE
    https://www.amazon.es/gp/product/B01J5RH5Y2/
    I have the first one and it is an outstanding card, it fits pefectly for my daily use. But the second one is much cheaper and the only difference i can spot is the V30 standar.
    The first one write about 90MB/s but the V30 in the second one is supposed to be 30MB/s.
    Is the second one really that slower?
    Thanks.
    USA
    Looking at the US Sandisk site, they make SD cards in several speeds. One at 300MB/s and a low end card at 48MB/s.
    It would more depend on what you plan to use it for. Static data storage, music or SD video, or in a HD video camera for capture?
    It's a long article, but this from Wikipedia does have the rating system down a bit lower in the article: https://en.wikipedia.org/wiki/Secure_Digital
    But others here may give you a better answer.
    Oct 2016
    Spain
    Thanks.
    No, V30 is basically the same as U3, it mark the minimun waranted write speed for a single file. They can be the same card from diferent batches being the marked V30 the newer one. Those 90MB/s is the maximun speed and those cards like most of the the cards marked V30 or U3 tend to be able to write faster that the speed waranted by the label.
    Sep 2008
    Spain
    I see, thanks both. I have marked 90MB/s with the original one.
