Hello everyone
I would like to know if it's possible to convert .srt subtile to .sub without to much trouble, my main goals is to add it to a .mkv file and be able to select the position of some lines during the movie, ( top of the screen )
I learned how to use SubtitleEdit but as far as I know I'm not able to do so.
Kalemvar1
Can't you make .ass/ssa subs with subtitle edit instead? I think you right click on the subtitle line if you want to change the position, etc. Save as .ass. Mux into to the mkv with mkvtoolnix. And see if your player support it.
Switch the output format to ASS/SSA. That should give you options to set top/left/right/mid/bottom. Once you've done that you can export the sup and they should be in the right positions.
(srt doesn't have multiple positions so any export of that format can't contain that kind of information) -
Although I've never actually used the feature, .SRT does provide for positioning. This is from the Doom9 Forum:
I haven't seen this format fully documented, so I got it from the source code to the SubRip program:
The format has no header, and no footer. Each subtitle has four parts:
Line 1 is a sequential count of subtitles, starting with 1.
Line 2 is the start timecode, followed by the string " --> ", followed by the end timecode. Timecodes are in the format HH:MM:SS,MIL (hours, minutes, seconds, milliseconds). The end timecode can optionally be followed by display coordinates (example " X1:100 X2:600 Y1:050 Y2:100"). Without coordinates displayed, each line of the subtitle will be centered and the block will appear at the bottom of the screen.
Lines 3 onward are the text of the subtitle. New lines are indicated by new lines (i.e. there's no "\n" code). The only formatting accepted are the following:
<b>text</b>: put text in boldface
<i>text</i>: put text in italics
<u>text</u>: underline text
<font color="#00ff00">text</font>: apply green color formatting to the text (you can use the font tag only to change color)
Tags can be combined (and should be nested properly). Note that the SubRip code appears to prefer whole-line formatting (no underlining just one word in the middle of a line).
Finally, successive subtitles are separated from each other by blank lines.
Here is an example of an SRT file:
Code:1 00:02:26,407 --> 00:02:31,356 X1:100 X2:100 Y1:100 Y2:100 <font color="#00ff00">Detta handlar om min storebrors</font> <b><i><u>kriminella beteende och foersvinnade.</u></i></b> 2 00:02:31,567 --> 00:02:37,164 Vi talar inte laengre om Wade. Det aer som om han aldrig hade existerat.
Do or do not. There is no "try." - Yoda
How to extract subtitles from a Blu-ray and convert to srt or sub/idx
By Baldrick in forum User guidesReplies: 35Last Post: 6th Dec 2021, 08:00 -
Modern Blu-ray player that supports SRT sub. via USB
By Thedane in forum Newbie / General discussionsReplies: 9Last Post: 23rd May 2015, 23:59 -
Simplest way to convert Blu-Ray .sup to .srt?
By Gurd99 in forum Newbie / General discussionsReplies: 2Last Post: 15th Apr 2015, 02:42 -
Why can't I find the subtitle (.srt) files on ripped Blu-Ray?
By JR.S in forum Blu-ray RippingReplies: 9Last Post: 25th Apr 2014, 10:58 -
blu ray iso to blu ray format
By minititan in forum Newbie / General discussionsReplies: 10Last Post: 30th Mar 2013, 15:49
