HI C**S
PLEASe I have a problem with ffmpeg:
I "feed" it with a series of files in "conCAT" mode and it work perfectly using and old (2014) ffmpeg 32bit version.
But using FFMPEG 64bit (the latest 25.02.2017 build)
using this commandline:
where the conCATlist.txt is a txt file like this:Code:ffmpeg.exe -y -f concat -i concatList.txt -filter_complex "[0:1] [0:2] amerge" -color_range 2 -vf yadif=1:tff,zscale=w=720:h=576:f=spline36:r=full,unsharp=luma_msize_x=3:luma_msize_y=3:luma_amount=0.8,colormatrix=bt709:bt601,interlace -color_range 2 -pix_fmt yuv422p -c:v libx264 -profile:v high422 -level:v 3 -g 33 -bf 2 -crf 15 -flags +ildct+ilme -top 1 -c:a ac3 -b:a 320k -ar 48000 -aspect 16:9 MP4concatenatoHDtoSD.mp4
I get an error:Code:file 'V:\errani\C0002.MXF' file 'V:\errani\C0007.MXF' file 'V:\errani\C0008.MXF' file 'V:\errani\C0009.MXF' file 'V:\errani\C0010.MXF' file 'V:\errani\C0012.MXF' file 'V:\errani\C0013.MXF' file 'V:\errani\C0014.MXF' file 'V:\errani\C0015.MXF' file 'V:\errani\C0016.MXF'
[Attachment 40756 - Click to enlarge]
Unsafe file name ... Operation not permitted
Can someone cat help me? thanks
FFMPEG -F Concat Video, Audio Sync Issue
By Shohag_ifas in forum EditingReplies: 2Last Post: 30th Nov 2016, 02:31 -
ffmpeg trim + concat = Non-monotonous DTS errors
By TorBru in forum Video ConversionReplies: 9Last Post: 27th Dec 2015, 06:33 -
ffmpeg "concat" question
By wallywalters in forum Video ConversionReplies: 3Last Post: 11th Jul 2015, 21:10 -
Virtualdub Job Control queue batch operation error
By brassplyer in forum EditingReplies: 5Last Post: 26th Dec 2014, 14:43 -
FFmpeg Runtime error / FFmpeg git-df82454 32-bit Static (2012-10-03)
By MashedPotatoes in forum Newbie / General discussionsReplies: 5Last Post: 6th Oct 2012, 18:22
