I use a stats script to display things such as frame drops, fps, etc (https://github.com/Argon-/mpv-stats), and while I get 0 dropped and mistimed frames, I get like 6-20 VO. What is VO, is it bad, and if it is, how do I fix it?
I believe "dropped" are frames dropped by the decoder while "VO" are frames dropped by the video renderer. So if "VO" increases often (not just when seeking or like twice an hour because of a slight timing mismatch between video and display) it could indicate a problem.
How to use mpv? (on Windows)
By Selur in forum Newbie / General discussionsReplies: 0Last Post: 14th Jan 2017, 07:04 -
Edit MPV and AC3
By Cherbette in forum EditingReplies: 5Last Post: 20th Sep 2016, 14:40 -
mpv playlists
By steve6 in forum Software PlayingReplies: 0Last Post: 19th Jun 2016, 07:45 -
MPV (media player)
By devilcoelhodog in forum Software PlayingReplies: 4Last Post: 3rd Mar 2016, 08:33 -
MPV Difference in Ubuntu and Window
By baoky in forum Video ConversionReplies: 0Last Post: 17th Sep 2014, 17:24
