Im animating in a 3d program and I would like to achieve that effect, its an useful idea to give the illusion of a big distance being travelled without actually moving the character or having to bother creating an huge 3d scenario to make the character fly across it very fast.
I just need to know how to achieve that from a picture, then use the colors of the picture to create that moving effect so I can loop it and use it accordingly. The idea is to create loopable backgrounds that simulate movement from a static picture or short sequence.. but again its 3d animation, i cant draw.
The 3d program is very basic, you can't do this, so i'll need to make it in Vegas or something.
I don't use Vegas so I can't give you instructions specific to that. But the general idea is to use a large background image and pan over it, then overlay your foreground. For example, here's a large background image:
[Attachment 40750 - Click to enlarge]
Here's how frames are panned over it (at 4 fps so you can see what's going on):
[Attachment 40751 - Click to enlarge]
and the final result at 23.976 fps:
[Attachment 40752 - Click to enlarge]
Repeat the sequence as many times as needed. Then overlay your foreground character.Last edited by jagabo; 26th Feb 2017 at 09:41.
In vegas , you keyframe the x position of the background layer (animate the layer horizontally) . You can apply a horizontal blur to the background image to get similar in characteristics to the cartoon background
If the motion is not horizontal (e.g. let's say your character is flying up at an angle), you wiould change the direction of the movement and blur to match
Help Cropping and Moving Video [Sony Vegas]
By MysticalMoonMan in forum EditingReplies: 1Last Post: 27th Oct 2015, 13:23 -
Sony Vegas: How to make a handheld effect?
By rocco123 in forum Newbie / General discussionsReplies: 6Last Post: 25th Sep 2015, 19:49 -
Suggestions/Help for Vegas Pro 12 effect -moving fog or mist?
By cdb in forum EditingReplies: 3Last Post: 2nd Mar 2015, 18:26 -
Effect FX Editing in Sony Vegas
By imrealdumb in forum EditingReplies: 14Last Post: 14th Sep 2013, 19:36 -
Video dissapears when moving in Sony Vegas Pro 11
By bitwi in forum EditingReplies: 2Last Post: 23rd Sep 2012, 02:21
