  1. Hi Forum!
    I need help!
    If i try to stream with ffmpeg like this command (ffmpeg -i http://someipadress:8080 -vcodec copy -acodec copy -f mpegts http://localhost:1234), comming error.
    How can I fix this?
    Thanks advance!
  2. Explorer Case's Avatar
    Feb 2004
    Middle Earth
    Why do you have output to local host over http, when you could just save as file? Perhaps there’s more to it that you’re not telling, like Wowza.
    ffmpeg -i http://server:port -c copy -f mpegts somefile.ts should indicate if the receiving part works.
    Perhaps you need to stream your output with a different protocol, e.g. rtmp:// or udp:// .
