Just created a vcd from a dvd and it plays fine using power dvd, but when i play it on my standalone player the audio seems to go out of sync.
Could this be a problem with my player. (i.e. cheap and nasty), or have i done something wrong?
yes i did have the same problem and there are just 2 standalone dvd players who can play the vcd/svcd just the way you like it. And the best is the pioneer dv444 (i just bought one)and players from jvc or another pioneer player.
If you have used tmpenc to encode your problem can be easily rectified,
just go to mpeg tools and select simple demultiplex, then remux using xing encoder, it'll take about 15mins, then burn as normal.
Hey presto no more problems!
Out of Sync only on Standalone player
By sambat in forum Video ConversionReplies: 2Last Post: 1st Sep 2011, 05:15 -
Standalone DVD recorder - is there and easier way to ensure audio sync?
By dphirschler in forum Video ConversionReplies: 20Last Post: 30th Dec 2009, 02:57 -
no audio in divx files on standalone player
By kaston in forum Authoring (DVD)Replies: 14Last Post: 27th Oct 2009, 21:26 -
Standalone Divx player out of sync
By Tool Man in forum Newbie / General discussionsReplies: 5Last Post: 18th Nov 2008, 19:31 -
no audio on iDVD-burned DVD when played on a standalone DVD player
By patroklus in forum MacReplies: 12Last Post: 10th Apr 2008, 12:56
