I'm trying out Staxrip again, I remember this to be an excellent encoder.
But....this time I have problems with getting any sound in my mp4 files. When I rightclick in the fields that should have contained soundfiles, I just find avs files.
Staxrip is mentioning about qaac: that it fail to locate CoreAudioToolbox. Maybe this is the problem? Does anyone know about this problem?
Results 1 to 10 of 10
qaac needs .dll files from Apple.
1. Download the iTunes 64 bit installer
2. get the portable installer from the qaac website
3. install 7-zip (or get portable 7z.exe)
4. move/extract all of the above into the same folder
5. run "makeportable.cmd"
6. move contents of the new "QTfiles64" folder to the qaac64.exe in the StaxRip folder -
Sorry, I jumped past that point, because I thought about 7z as a "zip" program (compression), and that windows probably had similar built in.
I installed 7z, ran the program "makeportable.cmd" and then I got the maps QTfiles and QTfiles64
I have copied the files in QTfiles64 into qaac folder, and will now check the Staxrip again. -
When I choose vob-files from dvd, it is working. Then the audio-field is filled with an audiofile. But not when I'm trying with the .mts file. It is also working when I choose a .mp4-file.
StaxRip
By stax76 in forum Video ConversionReplies: 675Last Post: 16th Apr 2024, 13:21 -
Where is 'sharpen' in new Staxrip?
By The.King in forum Video ConversionReplies: 0Last Post: 2nd Sep 2015, 06:44 -
which version of staxrip X64 support webm encoding?
By milad24 in forum Video ConversionReplies: 4Last Post: 22nd Jul 2015, 09:31 -
How can you use the best filters of StaxRip
By yaston in forum Video ConversionReplies: 3Last Post: 13th Jan 2014, 10:41 -
FFMPEG for APACHE 2.4.6 (x64), PHP 5.5 (x64), MYSQL 5.6 (x64) on WINDOWS 8
By Punctual in forum Video ConversionReplies: 5Last Post: 7th Aug 2013, 19:41
