Hi guys, can someone upload the plugin files for sony vegas 13?
When I want to install DebugMode Frameserver I can choose:
"DebugMode FrameServer Core (required)" -> yeah it will install it, but
"Sony Vegas (64-bit) Plugin" -> does not install. I also select "Desktop" as folder, but nothing appears there.
So that means it only installs the "DebugMode FrameServer Core" but not the Plugin for Sony Vegas
That is why I ask if someone is so nice and can upload the plugin for me.
Results 1 to 10 of 10
How do you know it doesn't install ? It doesn't install in the plugin directory. Are you looking in the correct place ? Did you try file => render as and check to see if it's an option ?
"dfscVegasV264Out.dll" should be in the "C:\Program Files (x86)\DebugMode\FrameServer" directory for 64bit vegas 13
"Frameserver.x64.fio2007-config" should be in the "C:\Program Files\Sony\Vegas Pro 13.0" for 64 bit vegas 13 -
And if those files were not installed or appear to be missing - try running the installer as administrator
dfscVegasV264Out.dll was in the folder yes.
"Frameserver.x64.fio2007-config was not. I was looking everywhere man. I also tried to install everything in 1 folder on the desktop, but it only install the core files.
The only file I could find with sony vegas was dfscVegasV264Out.dll
I also disabled firewall and antivirus.
I also started it as admin.
I just need the plugin files... -
It's just a config file, telling vegas where the debugmode directory is, where the .dll is located
You can do it in notepad, save it. Change the extension from .txt to -config
Make sure you have folder options set to see all filetypes (including hidden) and extensions . It might be there, but your folder view settings might be "hiding" it
Code:[FileIO Plug-Ins] frameserver=C:\Program Files (x86)\DebugMode\FrameServer\dfscVegasV264Out.dll
Just copy & paste that code into a textfile called "Frameserver.x64.fio2007.txt", save it . You need to enable viewing extensions in your windows explorer folder view options, otherwise you won't "see" the .txt extension
Then rename it to "Frameserver.x64.fio2007-config" . It gets put into the "C:\Program Files\Sony\Vegas Pro 13.0" directory
Make sure you close vegas, then restart it. Start a test project, something simple like a solid color on the timeline . File=> Render As should show debugmode as an option -
Picky TV doesnt work with some HDMI cables?
By jyeh74 in forum Newbie / General discussionsReplies: 36Last Post: 23rd Apr 2015, 13:20 -
Adding Subtitles using V/Dub on broken AVI file doesnt work. Help Please.
By Sulli in forum Newbie / General discussionsReplies: 1Last Post: 4th Feb 2013, 01:31 -
Subtitle merging doesnt work
By maxrockpro in forum SubtitleReplies: 0Last Post: 22nd Sep 2012, 15:53 -
Despot plugin does not work at all
By Umen Pich in forum EditingReplies: 47Last Post: 21st Jul 2012, 02:35 -
MeGUI MKV-Muxer doesnt work
By dag0 in forum Video ConversionReplies: 2Last Post: 7th Jul 2012, 04:10
