Can anyone please help i have created a vcd on a maxell cd-r disc, but when i place them in my sony dav-s300 player the display just comes up "no disc" please help. Is there anything i need to do. Could it be that the discs i am using are 80mins and should be 74mins. Please help as i am now getting very frustrated over this. Thanks for anll your help in advance Darren.
:D My Sony Dav-s300 can only play Platinum, Vivasat cd-r. Try one of those when you burning. I also discover that some cd-rw also can be played in dav-s300, byt I am still testing it.
The Sony DAV-S300 doesn't support CDR/RW playback (UK model). Therefore you will have to try different brands / dyes etc. to find one that works best for you. Obviously, tryong some of the above recommendations woul dbe a good idea!
Nick
blu ray player firmware update removes media compatibility sony bdp-s300
By cdcutlip in forum DVD RippingReplies: 9Last Post: 8th May 2011, 03:03 -
issues playing burned DVD's on sony blu ray player bdp-s300
By cdcutlip in forum DVD & Blu-ray PlayersReplies: 2Last Post: 7th May 2011, 16:12 -
BD-R won't play on BDP-S300
By pandemonium in forum Blu-ray RippingReplies: 24Last Post: 7th Jun 2009, 16:54 -
I have a Sony BDP S300 BluRay player, and the menu
By tzm in forum Authoring (Blu-ray)Replies: 2Last Post: 27th Mar 2008, 03:20
