Can't find proper instruction.
I use good old ifoEdit for strip DVD movie.
But ifoEdit create VIDEO_TS.IFO only for movie VOB's.
How to create IFO for these VOB files?
VTS_01_1.VOB
VTS_04_1.VOB
VTS_04_6.VOB
I need simple VEDEO_TS.IFO for playin all VOB's one by one. VTS_01_1.VOB first and then movie VTS_04_1.VOB ...
Results 1 to 20 of 20
I need edit IFO file. Or add some PCG instructions.
This is not about remux and demux videos. -
Like he said. If you want multiple IFOs (one for each VTS), and a VIDEO_TS.IFO to run them all, you need to use some type of DVD authoring program.
ifoEdit will create IFOs for each of the VTS sets, but only one at a time, and it re-writes the VIDEO_TS.IFO each time, so you can't play them all.
PGCedit can do it, but it's rather cumbersome. I've not used DVDStyler, but I have to believe it's easier than PGCedit.Do or do not. There is no "try." - Yoda -
And you don't think you might have mentioned that at the beginning?
Okay, here's another way. First open the VTS_01_1.VOB in DGIndex and Go File->Save Project and Demux Video. That will give you the audio, an M2V video and a D2V project file you can delete. Name them Part 1 or something. Then open the remaining VOBs in DGIndex, all of them at once. Save them in the same way and name them Part 2 or something. Delete the audio track that isn't the same (same number of channels, same bitrate) as the audio from the VTS_01_1.VOB.
Open Muxman and add the two video files, first the Part1 M2V, click on the 'Add' button and then Part 2. Do the same with the audio, Part 1, 'Add', Part 2. Give it a destination and 'Start'.
You could also remap the audio streams for the DVD you made in PGCEdit so the one you want is the first audio stream and then delete the other two, but that's more complicated. -
It's been a long day. So I must be missing something here.
Surely you do NOT need ifo's just to play vobs individually. -
@ manono,
I've already done all that stuff.
I've demux (streap) DVD and make 1st VOB with 1 audio and 2nd set with 2 audio streams.
At the beginning my target was create IFO's for playing all them sequentially.
P.S. DB83,
that excellent.Last edited by aptyp; 26th Feb 2017 at 01:06.
Once again, that's not what you asked originally. It's easy to do with your original DVD just by editing the IFOs a little bit using PGCEdit. There's even a current thread explaining how to do just that. Since it's your thread, did you do as _AI_ suggested?
https://forum.videohelp.com/threads/382626-%5BPgcEdit%5D-Go-to-Title-2-after-Title-1
I suggested in my last post that you keep the second one with just a single audio stream. Then, if both audios have the same characteristics, it's easy to do as I already explained.I've demux (streap) DVD and make 1st VOB with 1 audio and 2nd set with 2 audio streams.Last edited by manono; 26th Feb 2017 at 12:17.
@ manono,
Yes, I'm good.
PgcEdit is doing what I need.
I just interested in context of this thread.
You suggested about demuxing VOB files with DGIndex. Delete 1 audio from 1st VOB and keep 2 audio of 2nd VOB set. Then muxing them in Muxman? Later is remap audio streams with PgcEdit?
This quite messy procedure. Especially if I need to keep all three audio streams. Two streams with one bitrate and one is different. -
That's not what I suggested at all. I said:
The second set of VOBs comes with 2 audio tracks. I said to delete one so all sets of VOBs have one audio track, and those audio tracks must have the same characteristics (same number of channels, same bitrate).Delete the audio track that isn't the same (same number of channels, same bitrate) as the audio from the VTS_01_1.VOB.
Not as messy as you make it out to be. Demux, remove an audio track, reauthor. And that's what you asked for in both the title for this thread and in your first post. If you had asked how to make the DVD jump from title 1 to title 2 after playing, rather than go back to the menu, there would have been different answers, answers like the ones _AI_ gave in your other thread.This quite messy procedure.
Editing Tags in VOB/IFO files
By square_eyes in forum EditingReplies: 3Last Post: 7th Dec 2016, 22:58 -
playing ifo, bup, and/or vob files on Windows 10
By lunaverde72 in forum Newbie / General discussionsReplies: 7Last Post: 9th Mar 2016, 17:40 -
Why not just copy the VOB/IFO/BUP files?
By Matthias H in forum DVD RippingReplies: 5Last Post: 26th Jun 2015, 11:32 -
Create .ifo and .bup for multiple titles
By missberic in forum Authoring (DVD)Replies: 2Last Post: 22nd Jan 2015, 11:37 -
Creating ifo's for converted .vob files
By notsavvy67 in forum Video ConversionReplies: 4Last Post: 3rd Jan 2015, 07:28
