Results 121 to 132 of 132
Another possibility is to put the A2D Preferences/ Paths back to their default locations:
c:\users\userid\...
Just in case there are any file permission problems.
Does it fail on one particular webm file, or is everything failing ? -
Hi Sounds
That FF add-on seems to work well so far - https://addons.mozilla.org/en-US/firefox/addon/download-youtube/[/url]
It only seems to work on YouTube videos and not videos on other sites.
Have to you found it downloads MP4s from other sites besides YouTube?
It's still very helpful.
Thank you so much. -
I downloaded it as mp4 and converted it to an ISO and then burned it to a DVD watchable on a TV-DVD player.
No problem. I read about DeVeDe so I downloaded and installed it. It will converts MP4 files to ISO format. Then, I used Ashampoo to burn the DVD. Ashampoo doesn't seem to recognize VideoTS.
I couldn't get ASDtoDVD to convert so I just used what worked. I have no preference one over another - just whatever works.
Using the FF YouTube Downloader eliminates using VLC Media Player to convert .webm to MP4 for YouTube videos. Non-YouTube videos will still require the VLC conversion. -
Yes, I'm running that version on a W7 (32 bit) laptop. The file I downloaded and then installed is named devede-setup-3.17.0-build2.msi
I'm not sure of its limits and maybe it doesn't have the same capabilities as ASDtoDVD but it's fairly straight forward in creating an ISO.
Blu Ray and burning a Data Disc...not a Video Disc
By Moontrash in forum DVD & Blu-ray WritersReplies: 16Last Post: 16th Dec 2019, 23:18 -
burning dvd 9 disc
By anfield7 in forum Newbie / General discussionsReplies: 1Last Post: 24th Feb 2016, 09:29 -
Converting from a 'dvd shrink 3.2' VOB file to an mp4 file
By misstimtam in forum Video ConversionReplies: 6Last Post: 14th Jan 2014, 16:58 -
Problems with ffmpeg/mencoder burning subtitles to a mp4 file [h264 aac]
By landuchi in forum Video ConversionReplies: 0Last Post: 1st Oct 2012, 12:57 -
burning DVD from either .VOB or .mp4 files
By rosmari in forum DVD RippingReplies: 6Last Post: 16th Apr 2012, 12:56
. Did you download your webm as mp4 and convert it tovideo TS?
