If I use IEEE 1394 Firewire cable 4 to 6 pin to transfer*DV video tapes to computer, does*higher quality cable improve*"picture" quality than stock cable since my target is PC ?
There are many companies selling this cable at high cost and say improve picture. However I experienced little with power source but seems my Panasonic NV-DV 2000 doesn't make any different.
Anyone know for sure ? And thank you for answering.
Results 1 to 14 of 14
Impossible, unless the cable is producing so many errors that there is no longer enough bandwidth to transmit the data in real time a cable with have ZERO difference in quality through any kind of digital video.
When a HDMI cable isn't good enough to transmit a picture it's not color, sharpness, resolution or brightness that you lose, entire sections of the screen simply cease to exist. If you think you're seeing anything else then it's simple placebo effect. -
firewire cables either work properly or not at all. there is no in between. you can have an intermittent short where you can bend the cable one way and it works and the other where it won't but that's just a bad connection and it would be time to throw out that cable.
"The greatest trick the Devil ever pulled was convincing the world he didn't exist."
After experince from DVD or Blu ray to TV there is much improvement both V&A with high quality cable.
Looking for a good ieee 1394 PCI card
By EZ Video in forum Capturing and VCRReplies: 5Last Post: 12th Aug 2014, 21:45 -
Will I lose much quality if I use a firewire to USB cable?
By seven1970 in forum Capturing and VCRReplies: 12Last Post: 24th Dec 2012, 23:06 -
IEEE 1394 Capture from DVHS on Windows XP SP3
By Shelby68GT500 in forum Capturing and VCRReplies: 2Last Post: 28th Nov 2012, 16:07 -
Firewire and USB 2.0 Cable quality - does it matter???
By tarrickb in forum Capturing and VCRReplies: 21Last Post: 29th Mar 2012, 12:59 -
Canon HV20/30/40 IEEE 1394 connectivity issues with Windows XP
By E_D_George in forum Newbie / General discussionsReplies: 19Last Post: 4th Mar 2012, 13:32
