Thread necromancy department...This is kind of a forlorn hope, but I'm wondering if there has been any movement on this subject over the past 8-1/2 years?
I have been capturing off my Mitsu HS-HD2000U using S-Video to my Hauppage capture card, but if it were possible to eliminate losses by using FireWire, I would. Any custom drivers out there that anyone knows of? I'm also possibly considering a Sony GV-D200 or -D800 to capture 8mm video...how compatible is that with FireWire on a PC?
Truthfully, my source material is consumer-grade reused VHS tapes from the '80s, mostly recorded on a stock GE camcorder or else a low-end VCR. So I'm not expecting any great improvement in quality. (My family and friends are thrilled at the quality I'm getting now from S-Video). Still, I'd like to be able to work at whatever quality level the source will support. Any ideas?
--------Eric H. Bowen; USN Battleship Veteran (USS Missouri, BB-63, 1985-88)
16" Armor Piercing - When you care enough to send the very, VERY best! -
Unfortunately no. I own three of these VCRs (two in use for capture, one backup still sealed in box). The FireWire connection is very specifically locked to a handful of compatible decoder boxes and a couple Mitsubishi TVs that were discontinued ten years ago. The 2000 won't communicate with generic PCs or capture hardware. I believe some of the JVC DVHS models can be used for direct FireWire capture, due their more elaborate digital/analog system. But the simplified Mitsu interface was proprietary and limited.
About what I figured. Oh, well. Wish I knew more about hardware and writing drivers. At least the S-video quality I'm getting from the VCR is quite good.
Issue with Canon HV 40 Capturing BLOWN FIREWIRE?? Dv to HDV?
By ducksalot in forum Capturing and VCRReplies: 11Last Post: 26th Sep 2016, 11:27 -
I am considering capturing via FireWire
By Hypersonic1 in forum Capturing and VCRReplies: 70Last Post: 30th Aug 2015, 10:04 -
Capturing From Legacy JVC-GRDV-21U (Firewire)
By fishnmgn in forum Capturing and VCRReplies: 2Last Post: 16th Jun 2014, 20:56 -
Capturing to DV AVI without Firewire.
By mrtobor in forum Capturing and VCRReplies: 16Last Post: 25th May 2012, 22:55 -
Capturing DV camcorder to laptop w/o firewire port
By fvisagie in forum Capturing and VCRReplies: 33Last Post: 17th May 2012, 13:14
