  1. My video is synced and sounds perfect in preview, but once i export the video as .avi, part of it becomes very loud static. I need a way to fix this. Does anyone know how to fix this?
  2. Did you try selecting an audio codec, or was it uncompressed pcm wav in the AVI container?
    A workaround you can try might be to export the audio separately , alone, then mux it together with something like vdub
    Or maybe try exporting another format like MP4 then muxing the audio with your desired video
    These are just guesses. I tried VSDC and didn't like it very much.
  3. I did try exporting in another format (wmv), and it worked. Thanks for the help!
