If I wanted to upscale 24p to 48p, what software will provide the clearest motion with the least artifacts?
Thanks in advance!
I've had good luck with this free avisynth plugin. Should work well when it's just doubling the frame rate, but it supports 3x and more but with worse results. They also have a payed version. Other payed products will probably be better but I barely use the free version I mentioned.
Here's SubJunk's thread on the AviSynth filter Interframe, which is designed to do what you're asking:
http://forum.doom9.org/showthread.php?t=160226&highlight=double+framerate -
You get about the same amount and degree artifacts with them all, even twixtor, in "automatic" mode .
The exception is when you use guide the motion estimation with user input using the "pro" versions (twixtor pro, kronos) using things like motion tracking, mattes, splines. It can be very time consuming depending on the type of content. Some types of content cannot be interpolated very well regardless of what you do - low motion samples (e.g. low rate cel animation/ cartoons ) , motion blur, object deformations
So if you were going to use them in "automatic' mode, then don't bother spending any money . Use one of the mvtools derivatives -
Motion Interpolation (VidFIRE) Software?
By goodiesguy in forum Video ConversionReplies: 41Last Post: 5th Mar 2016, 17:43 -
Delete
By killerteengohan in forum Newbie / General discussionsReplies: 0Last Post: 30th Aug 2014, 23:15 -
Motion flow interpolation software?
By lordsmurf in forum Newbie / General discussionsReplies: 18Last Post: 27th Jun 2014, 10:30 -
How to convert 25p to 50p with motion interpolation?
By Bencuri in forum Video ConversionReplies: 7Last Post: 23rd Jul 2013, 18:23 -
Deinterlacing: Edge Detecting Interpolation Versus Motion Compensation
By NY2LA in forum Video ConversionReplies: 2Last Post: 30th Jun 2012, 08:06
