I am about to upgrade in order to edit analogue and dv and am being persuaded to have the ATI Radeon 64mb DDR card. I am not too happy that the ATi website for the product suggests that only Ulead Video Studio software is compatible. True/false?: And if the latter what are the problems for, say, MGI or Pinnacle software instead. Views on best alternative cards also appreciated please.
Hugh Allen
You didn't specifically say that the card was an ATI All-in-Wonder card. A standard Radeon card doesn't have the video inputs, it has to be an AIW version.
I have been using mine for a month now and all in all I give it about a 7 out of 10. Since the AIW relies on the cpu to do the capture, a h/w based capture card like the Dazzle VC2 would probably be better, but for a general purpose card that does a pretty good job at everything the ATI is a good choice.
You can capture in various formats (AVI, MPEG1 & 2) and those files should work in most applications. In fact they have for me except in Pinnacle Studio 7, but maybe it was me. Right now I am evaluating Ulead VideoStudio 6 and it seems to work pretty good. I may go back to version 5 since that came with the card.
My recommendation is for the absolute best video get a separate card like the Dazzle. If you can live with something that is very good but not the best, then the ATI is a good way to go. You'll just have to experiment with the settings a bit though to find what works best for you. -
I think you may have misunderstood. The card spec that I refer to is at www.ati.com/products/pc/radeon64ddr/index.html andspecifically says it is VIVO. Is it me or you?
HGA -
All I can tell you is that the Radeon cards are not compatible with the better editing software. I'd personally recommend that you go with a 3D-only card like a GeForce4 plus a dedicated capture card OR a DV-converter like a DV camcorder with analog in or the Sony analog-to-Firewire. This will greatly simplify captures for you, short of going to a full-blown professional solution like a Canopus or *shudder* Matrox.
Okay, it's a VIVO card. It doesn't have the TV tuner that the AIW has, but does have an S-Video input.
I agree with TVC that the best solution would be to get a 3D card and a separate capture card.
However, I do disagree with the assertion that the ATI output is incompatible with most software. That might have been true in the past, but I have used the last three versions of their software and it has worked fine. There is a registry tweaking tool that is painless to use and will adjust the MPEG2 output file to be SVCD compliant. I didn't find it mandatory to use it, though. -
What I mean to say is that ATI cards have compatibility problems with captures in applications like Adobe Premiere and some other semi-professional solutions. Only Ulead seems to be compatible. Now, I haven't checked out Video Vegas and some other programs, but no Premiere support is a huge pain for me. However, if someone does know how to make an AIW card capture in Premiere without taking up 1GB/minute and not having the capture settings reset themselves, I'm all ears. I'm still in a learning mode here when it comes to this oddball configuration.
To me, Sony's Firewire DV-analog standalone converter + any OHCI-compliant Firewire card is the easiest and most compatible solution overall short of all-out professional solutions. Analog capture cards are strange creatures not to be taken lightly. ATI's abysmal customer support and drivers (that required a reformat of my XP install) should be warnings to people to stay away from those cards unless they can live with the included software and not ever want to upgrade.
Ulead video studio 8 help
By the big man in forum Newbie / General discussionsReplies: 2Last Post: 22nd Jun 2009, 16:02 -
Ulead Video Studio 9 - colorspace
By Froddy1 in forum EditingReplies: 0Last Post: 2nd Feb 2009, 10:49 -
Ulead Video Studio 10 avi help
By theguy1991 in forum Newbie / General discussionsReplies: 15Last Post: 25th Oct 2007, 15:57 -
Does anyone use ULEAD Video Studio 10?? or any suggestions?
By cmlmich in forum Newbie / General discussionsReplies: 1Last Post: 2nd Jun 2007, 22:12 -
Ulead Video Studio 7 SE
By uricktam in forum Newbie / General discussionsReplies: 1Last Post: 10th May 2007, 11:14
