I am trying to make from these three slides they are and in arc soft stitch it it can stitch the 3 without problem and align it, but The script is giving me error even If I go and make manual adjustments and using the proper crop after first slide.I aligned them better then the stitched picture you managed to make video of I open the picture again alone in avspomde to have 2 windows and in second I measure the coordinates I go to first script left corner and last frame up left corner I use the data from the second in to script and still get error of crop
Results 31 to 33 of 33
Thanks Jagabo I confused with last before last frame in a strip now everything works fine, here is 3 s example of 4 in a row strips, I will do a lot of experiment with scanning 8mm films in next days. 8mm transfer is rarely present on forums. Another thing that happens and I didn't expecting it is I opened first avi in vdub append second and it "stitched" all others in a folder at once which cut the work significantlyI explained to you what the likely problem is.
Another question on 8mm film to digial ....
By xtal_01 in forum Capturing and VCRReplies: 1Last Post: 24th Feb 2016, 18:54 -
8mm Film Restoration
By TekVilla in forum RestorationReplies: 252Last Post: 22nd Jan 2016, 11:31 -
What resolution is 8mm film?
By Mephesto in forum Newbie / General discussionsReplies: 20Last Post: 18th Jun 2013, 23:08 -
Have about 50 8mm film to capture, what to do?
By impmon2 in forum Capturing and VCRReplies: 9Last Post: 14th May 2013, 22:41 -
8mm Film Capture?
By Retrosonic in forum Newbie / General discussionsReplies: 0Last Post: 4th Nov 2012, 07:35
