Hello
I have video MXF files on my computer that I need to edit.
Each MXF folder contains the following files:
CIF file
XML document
MXF file
SIF file
Can anyone suggest how I should go about editing these- which programme to use and whether I need to convert the folder/files before I edit?
Thanks,
Louise
	Download the trial version of Premiere Pro.
 These are probably from a Canon camera. The xml indicates folders may contain spanned clips.
 Load the entire file structure into Premiere and determine the actual properties of the video files (XDCam, AVCHD, etc.) MediaInfo will also work, but Premiere will tell you more in this case.
 If you can get the job done in less than the trial period (30 days I believe) Just continue working in Premiere.
 Once you know the actual properties of the video files report them back here if you need further options.
	In the meantime- do you know if there is a way I can view the video clips prior to starting the free trial of Premiere Pro?
	use ffmpeg to convert to a lossless or frameserve it via pipe. (note: i'm not a "pipe" expert, so someone else will have to answer that if it becomes how-to question from you)
 the code below will convert the mxf file into a UT code video file:
 or, to "cut" a small sample to test, (because your file may be a huge mxf) use the following w/ { -t timecode } in ffmpegCode:ffmpeg "mxf_file.mxf" -vcodec utvideo -pix_fmt yuv422p -an -y "output_mxf_file.avi"
 whereCode:ffmpeg -t 00:00:10 -i "mxf_file.mxf" -vcodec utvideo -pix_fmt yuv422p -an -y "output_mxf_file.avi"
 { -an } means to exclude the audio in the conversion
 { -t timecode } means to "cut" the first 10 seconds out of the mxf file and convert it to UT codec video. the -t and -ss format is hh:mm:ss.milisec, ie 01h:15m:5s.2milisec
 this cutting method cuts at the beginning of the mxf file. if you want to cut in some mid section (to test) then u have to add the { -ss timecode } position parameter.
 be warned that converting a huge file may take a long time to complete. that is why i gave you the "cut" option--to give you the opportunity to taste this alternative method.
 see the documentation for more info on that -ss and -t and other usage.
  Audio Problem with MXF File ConversionBy Carl Enslin in forum AudioReplies: 8Last Post: 24th Dec 2014, 09:05
  Audio Problem with MXF File ConversionBy Carl Enslin in forum Video ConversionReplies: 2Last Post: 23rd Dec 2014, 14:03
  if I have a .mxf file, what is the best to load it on VirtualDubMODBy marcorocchini in forum Newbie / General discussionsReplies: 3Last Post: 11th May 2014, 11:06
  audio from .mxf file with FFMPEGBy marcorocchini in forum Newbie / General discussionsReplies: 4Last Post: 27th Dec 2013, 18:29
  MXF Reference fileBy Martynguk2002 in forum Video ConversionReplies: 1Last Post: 22nd Oct 2013, 08:48
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
