I've recently made a HTPC with some spare parts and all is super good!
But when suing VLC on my old plasma, which is 720p, I am getting small vertical black bars on some of my video. I don't get these on my Dell 24" monitor. Is there something I'm missing here? I know VLC is supposed to play the video as it is, but I am curious as to why I get the full 1920 resolution on my PC monitor but not TV. I have tried changing aspect and crop to no avail. It is not bad, but it is a bit weird having those vertical bars. Not sure show I can stretch them a bit, or if I'm way off base.
'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
What's the native resolution of the Plasma? What resolution is the PC set to? My guess is the PC is set to the native resolution of the plasma but that resolution isn't 16:9. If that's the case then you can set the Monitor Pixel Aspect Ratio in the video section (show all settings) of VLC. Your graphics card's drivers may also have a setting for this.
@jagabo
Thank you for your post. This is an older SAMSUNG 50" 720p Plasma HDTV PN50A450.
The specs state:
So then I need to ensure that my video card is set to 1365x768 right? Or can that be adjusted in the pixel aspect ratio you mention?With a maximum resolution of 1365x768 (16:9), the widescreen Samsung PN50A450 fully supports up to HDTV 720p (1280x720, progressive) for a truly high-definition experience.
thanks!'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie -
1365x768 is a 16:9 frame size. Setting any 16:9 size on your computer should give you a picture that fills the frame -- assuming you're playing 16:9 video that fills its frame (eg, a 2.35:1 movie will not fill a 16:9 frame). I don't know if your graphics card will allow 1365 pixels wide. You may have to use 1366. Or even 1280x720.
@jagabo
Thanks for your help...there was, buried deep in the driver options, a scaling factor that had a default that was causing some scaling issues. All fixed!
thanks again'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
1440x1080 with black bars
By ValDaHus in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 10Last Post: 25th Jul 2015, 18:25 -
Removing black bars with VLC
By Roméo Latour in forum Software PlayingReplies: 2Last Post: 7th Apr 2015, 11:41 -
Vertical Artifacts/bars on video
By dr-love55 in forum RestorationReplies: 5Last Post: 28th Dec 2013, 00:41 -
how do I add black bars?
By Onceler2 in forum Video ConversionReplies: 8Last Post: 31st Jan 2013, 11:08 -
Why are there black bars at the sides?
By pooksahib in forum Newbie / General discussionsReplies: 12Last Post: 18th Apr 2012, 09:11
