Hi all,
I just switched to Dvd2svcd which I find a graet prog but the prob I am having is in high motion scenes the picture appears blocky, even though I am using the highest Possible bitrate for svcd. (2520) other than that the pictue and audio is fantastic. I am using alll the bundled software and TMpGenc 2.53 for encoding. I was wondering if anyone could kindly give me a few pointers about this.
Source is DVD:
PAL, Interlaced, 25fps, 16:9
Any Ideas or settings for this source would be appreciated.
Try setting motion serach for "Highest Quality (Slowest)" and use 2-pass VBR instead of CBR (I assume that's what you are using)
DiVX (AVI) to (S)VCD using DVD2SVCD
By LeeBear in forum User guidesReplies: 125Last Post: 4th Jul 2008, 17:01 -
Help Please, Error message while using DVD2SVCD and TMPGEnc 2.5
By FizzFozz in forum Newbie / General discussionsReplies: 1Last Post: 16th Apr 2008, 16:28 -
DVD2SVCD Vista compatibility
By Kibble in forum DVD RippingReplies: 5Last Post: 19th Mar 2008, 09:51 -
DVD2SVCD with CCESP 2.70 - CBR 6kbps? No way around?
By Colmino in forum Newbie / General discussionsReplies: 1Last Post: 6th Jan 2008, 00:48 -
AVI,DivX,XviD to DVD with switchable subs using DVD2SVCD
By Baldrick in forum User guidesReplies: 18Last Post: 6th Jul 2007, 16:08
