Hi
I want to copy my blu-ray and dvd movies to the hard drive on my laptop computer; and be able to play them back at a later time without dragging the external blu-ray player around with me.
I understand that I need to 'rip' the movies, but there seems to be so many formats that I have no idea what to use/do
For playback, there are notes on the web that Cyberlink Power DVD copies and distributes too much personal data (which I don't like), so I am looking for an alternate player.
Any suggestions on tools for ripping, what formats to use, tools for playback on Windows 10 would be greatly appreciated.
Thank you
A "rip" is an exact copy of the disc.
VLC media player will play anything you can throw at it. -
MakeMKV is free for Blu-ray ripping while in beta, but if you like MakeMKV well enough to use it long-term, consider buying it to encourage continuing development. If the current version asks for a key, that may be obtained here: https://www.makemkv.com/forum2/viewtopic.php?f=5&t=1053 Use MakeMKV's "Save selected titles" feature to copy the main movie to MKV format, which is playable with VLC, MPC-HC, or PotPlayer. PotPlayer is my favorite, but I also use the other two.
If you want to have full Blu-ray menu support, then use MakeMKV's Backup feature to copy all the files and folders on the disc to your HDD. (The Backup feature is not available for DVD.) A licensed player like PowerDVD Ultra or Corel WinDVD Pro is still the best choice for full menu support.Ignore list: hello_hello, tried, TechLord, Snoopy329 -
It's well worth buying the license for MakeMKV just in case in certain litigious jurisdictions attempt to close it down. Excellent program and simple to use.
SONY 75" Full array 200Hz LED TV, Yamaha A1070 amp, Zidoo UHD3000, BeyonWiz PVR V2 (Enigma2 clone), Chromecast, Windows 11 Professional, QNAP NAS TS851 -
dmc, in the future please use a more descriptive subject title in your posts to allow others to search for similar topics. I will change yours this time. From our rules:
Thanks,Try to choose a subject that describes your topic.
Please do not use topic subjects like Help me!!! or Problems.
Moderator redwudz
And welcome to our forums.
To clarify, if you play a DVD on VLC, there's a "record" button on the player that will begin storing the playback on your hard drive (in a designated location) in the same format the video was already in. (For example, on a DVD, it'll store as an .mpg.)
I've found it doesn't always work. Sometimes the recording just won't store properly, with segments all disjointed. Often (over the last year or two), it produces a stored file that shows no video. Only the audio will play. That file, tho', if run thru AVIdemux, will come out in a form that once again has the audio and video and will play normally. A "lumpy" two-step process, granted, but still do-able. (It also gives you the option of converting the video to an .mp4 in the process, tho', which certainly is a plus.)
3D Blu-ray Rip to Hard Drive
By Xolo in forum Blu-ray RippingReplies: 7Last Post: 29th Jan 2014, 14:45 -
Copy Blu ray Disc to Hard Drive
By Mathan82 in forum Blu-ray RippingReplies: 12Last Post: 9th Jul 2012, 12:52 -
copy dvd movies to blu-ray
By fredreed in forum Authoring (Blu-ray)Replies: 54Last Post: 20th May 2012, 15:18 -
DVD-R to dual layer, blu-ray or hard drive? Possible?
By daysaf00 in forum Authoring (DVD)Replies: 4Last Post: 24th Mar 2012, 14:50 -
Can I use my DVD Drive to Rip Blu-Ray Movies ?
By augustya in forum Blu-ray RippingReplies: 25Last Post: 2nd Mar 2012, 13:07
