I use Red SmartLav + with my cell phone and find it difficult to edit sound with the video in Filmora 8.
Spend a lot of time to get lipsync as good as possible...
Any suggestions on how I can do this in the best possible way?
Just a remark regarding sync - when I use my older computer playing videos, it already makes a difference if I do full screen or just a frame. Full screen it becomes seriously out of sync - same video.
So player and the power of that computer also makes a difference.
The computer I edit video on is not online, but probably less difference since powerful machine in comparison.
But things that may relate to your issue is what soundcard and drivers you have used, it's about latency for playback.
Usb soundcard usually have more latency, and DirectSound is worse than ASIO etc.
Some editors let select soundcard settings, and some relie on OS settings in Windows etc.
In some players for DVD and such I have a setting to adjust delay of sound compared to video to sync on LCD monitors.
That is yet a source for issue. Zero to 40ms is setting on one, so high latency soundcard with 10ms or more could make a difference. I certainly notice difference of 10 ms when changing in steps of 10. -
Cell phone videos are usually VFR (variable frame rate) . Almost impossible to edit and keep in sync in most programs unless you convert it to CFR (constant frame rate) first
Can Filmora reverse videos without the audio going out of sync?
By BBGFY in forum EditingReplies: 2Last Post: 4th Dec 2016, 04:18 -
Wondershare Filmora...AVOID
By ayoshak in forum Video ConversionReplies: 2Last Post: 15th Jul 2016, 08:25 -
Never heard of this one before . . . (Filmora)
By Seeker47 in forum EditingReplies: 4Last Post: 11th Jun 2016, 06:55 -
Realistic lipsync animation
By jimmyy in forum EditingReplies: 17Last Post: 13th Jan 2013, 16:06 -
Converting To HD - Lipsync Problem
By aaronoafc in forum Newbie / General discussionsReplies: 7Last Post: 24th Jun 2012, 13:19
