I have a bad english. Hopefully, you will understand my problem. I bought a few days ago in this program:
http://www.magicdvdripper.com/dvd-ripper.htm
I ripped its applications as DVD-5 size. "Split dvd-9 into two dvd-5 discs. It forms two folders in the folder where 1 is the extras, etc., And the second film. I use the latter.
How and in what way I can make high-quality mp4 or mkv
* file. The purpose is to burn a DVD disc. The disc size is 4.7GB.
So, to convert the instructions. High quality mkv or mp4 file. This is my own bought a DVD disc, that I want to burn another disc that includes only bring the film ..
I would ask the instructions ..
If the source and destination is DVD format, then you do NOT want to convert to mp4 or mkv.
I've not used that software, so I can't comment on how it works.
Basically, you want to RIP the DVD contents to the computer. Most programs that RIP discs, will create a single folder (ie: copy of the original disc) on the folder. You could then use a program such as DVDShrink to create a movie only DVD5 image.Google is your Friend -
How does DVD Shrink will record a DVD-5 size. I have a film that burned more than 6 GT
Begin....
I found in the guide. Thank you. "DVDShrink"
Magic DVD ripper
By DaneClark in forum DVD RippingReplies: 1Last Post: 15th Jun 2016, 19:35 -
Any Video Converter, problem with
By ibzomie in forum Video ConversionReplies: 2Last Post: 10th May 2016, 22:39 -
Problem with HDMI to RCA converter
By alien91 in forum Video ConversionReplies: 6Last Post: 6th Aug 2015, 14:22 -
FREE New MyBD Blu-ray ripper, decrypter, scaler & converter to h265
By Mateo Dalmas in forum Latest Video NewsReplies: 24Last Post: 30th Oct 2014, 10:05 -
TAudioConverter 0.9.5-Multithreaded Audio Converter-Extractor CD ripper
By ozok in forum AudioReplies: 69Last Post: 24th Jul 2014, 00:26
