Hi everyone,
Can someone ley me know how to "use" this subtitle ? I found the subtitle on the internet in text format, yet the format looks weird to me...
Sample as follows:
{1}{90}movie info: 640x480 29.969fps 177.6 MB|/SubEdit b.3827
{94}{}Subtitles by wadera8@wp.pl
{959}{}04 Equal Measures
{1847}{}Optimus to Command Center.
{1901}{}Scrub the mission!
{1952}{}Looks like one extremely ill wind |is blowing our way.
{2081}{}Command center! Do you read...!?
{2430}{}That does it.
Thank you very much in advance.
	You could try open in it in Subtitle Edit and see if it can identify the format. Save as srt.
	Looks like MicroDVD format. The problem is the end frame numbers (second {}) are missing.
	Concur. I'm guessing the lines without the second frame number are supposed to be "infinite" (i.e. displayed until the next subtitle starts). You would need to open it in a text editor and supply the missing numbers before trying to convert it.
 Subtitle Edit will open it, but any lines that are missing the ending frame number will have a zero duration.
 AegiSub will also open it, but any lines that are missing the ending frame number will be ignored.
 Either way, you have to set the video frame rate before opening the file in order for the frame codes to be converted correctly to time codes. In Subtitle Edit, go into Settings and set the Default frame rate to match the video you're working with. In AegiSub, you have to actually open a video file — ideally the actual video the subs are for — or Use Dummy Video in the video menu, and give it the correct frame rate.Do or do not. There is no "try." - Yoda
  .sup subtitle helpBy gotitbro in forum SubtitleReplies: 7Last Post: 29th Aug 2018, 15:12
  Showing subtitle in Reverse Order | Arabic Subtitle - Samsung LED 49K6965By ashkan_vpm2 in forum SubtitleReplies: 2Last Post: 10th Feb 2017, 02:51
  Convert pac subtitle to something that I can open in Subtitle workshopBy Tiger_1982 in forum SubtitleReplies: 11Last Post: 15th Aug 2015, 21:49
  Subtitle-fuBy KraG in forum SubtitleReplies: 5Last Post: 15th May 2012, 20:44
  convert 1 CD subtitle to 2 CD subtitleBy nirbhayn in forum EditingReplies: 7Last Post: 10th Apr 2012, 04:44
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
 Quote Visit Homepage
				Visit Homepage
