  1. I followed the directions for tmpgenc and burn it with vcdeasy to VCD to play on my dvd. But subtitles on my animes get cut off. The quality is fine its just I can't see the subtitles. Its half cut off. Help! Thanks.
    Apr 2002
    Edmonton
    Did you remember to set the aspect ratio?
    Have Burner will Travel
  3. I just learned No television can fit the entire screen of a movie, and tv's usually cut about 5-10 percent off the corners of vcds. I know how u feel man, the only vcds i make is anime. But the thing with your anime is, most likely your anime is a fansub. And usually when it's fan subbed the person who encoded them put the subtitles waaay at the bottom. Anyways, I used Panasonic Mpeg1 encoder, and they let you add borders around the movie. I put about 24 lines off the top/bottom left/right and it looks right on my tv. I hear you can crop with tmpg also, but I don't know how
