While at work today I obtained several short avi videos from a dash cam for an investigation. During playback on the owners computer I was able to double click and view a second file which appeared to be embedded within the file. There were two cameras hooked to the system. One forward facing and the second rear facing. We opened the file in MPC but I am so far unable to achieve the same effect in the office. I have never seen or used a file like this before so am stumped. Any help would be appreciated.
In the MPC 'play' menu, you should be able to select 'Video track'.
To extract the 2nd video, this ffmpeg command should work:(from source file '0', select 2nd video stream '1')Code:ffmpeg -i "your-video.avi" -map 0:v:1 -codec copy "your-video-2.avi"
https://ffmpeg.org/ffmpeg-all.html#Advanced-options
Stream 0: audio first, then Stream 1: video PROBLEMS
By andwan0 in forum Newbie / General discussionsReplies: 5Last Post: 9th Dec 2016, 17:34 -
Issue with Yamb and MP4Box (adding audio-stream to video-stream)
By slax65 in forum Video ConversionReplies: 2Last Post: 21st May 2015, 05:39 -
Computer shows RW discs as having double files (double content)
By gastrof in forum Newbie / General discussionsReplies: 5Last Post: 7th Feb 2015, 01:17 -
i have a stream capture video but the stream was laggy. how to fix video?
By 00900 in forum Video Streaming DownloadingReplies: 2Last Post: 8th Apr 2013, 20:15 -
Flash .flv video out of sync (original video is perfect with double audio s
By TACtech in forum EditingReplies: 2Last Post: 3rd Apr 2012, 12:13
