Hi Y'all,
so I'm backing up my DVD collection after my child has turned some into lovely coasters. That being said I am having some issues with avatar I am using handbrake and WinXDVD for when one doesn't work I use the other. So I have the 3 disc set now I am able to rip part 2 just fine but no mater how I rip part 1 and no matter what app I'm using the last chapter doesn't rip! Is there something I'm missing? I thought maybe the DVD was messed up but it works fine. Fyi I get the result using both apps or ripping the extended cut or regular version it still ends somewhere between the 16th and 17th chapter and there's 19 any thoughts?
2nd, how do I make them one dvd instead of 2
Rip each disc to the hard drive using MakeMKV. This will give you the main movie in MKV format from each disc.
Then use MKVToolnix to combine the two MKV files. Import the first disc MKV, then right click on it within MKVToolnix and choose Append to add the second MKV file. Output will be one joined MKV file that isn't compressed.
If you want to compress it to a smaller size, use Handbrake to make a new, smaller MKV or MP4 file. If you want a DVD-video output, import the combined MKV file into AVStoDVD, though quality may suffer if you try to make a DVD that will fit onto a single layer DVD.
Basic Advice on BR Ripping
By djtech2k7 in forum Blu-ray RippingReplies: 15Last Post: 28th Aug 2013, 18:57 -
Ripping parts of blurays to re-author as demos.
By AussieGuy1970 in forum EditingReplies: 8Last Post: 27th Aug 2013, 04:20 -
Blu Ray Ripping Advice
By cozzy2008 in forum Blu-ray RippingReplies: 2Last Post: 10th Nov 2012, 14:06 -
Some advice on ripping TV series from Blu Ray
By strontium_99 in forum Blu-ray RippingReplies: 4Last Post: 31st Jul 2012, 07:13 -
First Time Ripping...Looking for advice...
By zagro002 in forum DVD RippingReplies: 10Last Post: 19th Apr 2012, 00:07
