In VLC when you Convert/Save, you can specify the exact starting place in the source file as an HH:MM:SS offset. But I do not see a place to specify the *duration*. Or even better would be a way to specify the exact time offset of the end. Is there any way to do this?
Results 1 to 1 of 1
VLC audio sync problem after conversion
By devium in forum Video ConversionReplies: 5Last Post: 1st Apr 2023, 15:36 -
HandbrakeCLI and setting chapter duration
By VideoGuruDude in forum Video ConversionReplies: 1Last Post: 6th Oct 2014, 22:22 -
MKVmerge extends total time if subtitle duration exceeds video duration
By ankutsa in forum SubtitleReplies: 1Last Post: 7th Sep 2013, 11:08 -
Need help with VLC command line conversion.
By NGage^ in forum Newbie / General discussionsReplies: 0Last Post: 13th Oct 2012, 11:20 -
VLC audio 5.1 and stereo setting for reglar speaker 2.0
By vampelle in forum Software PlayingReplies: 0Last Post: 28th May 2012, 09:53
