Page 9 of 34
FirstFirst ... 7 8 9 10 11 19 ... LastLast
Results 241 to 270 of 994
  1. Member xplorr's Avatar
    Feb 2017
    Europe
    Originally Posted by ShawnR4 View Post
    Hi, I want to download 'Ella' from VTM.be
    I've made a working account ant typed it in the software as needed, but it doesn't work...
    The terminal promt sais:
    [Medialaan] 257709150377000: Downloading webpage
    File "__main__.py", line 19, in <module>
    File "youtube_dl\__init__.pyo", line 465, in main
    File "youtube_dl\__init__.pyo", line 455, in _real_main
    File "youtube_dl\YoutubeDL.pyo", line 1958, in download
    File "youtube_dl\YoutubeDL.pyo", line 776, in extract_info
    File "youtube_dl\extractor\common.pyo", line 434, in extract
    File "youtube_dl\extractor\medialaan.pyo", line 168, in _real_extract
    IndexError: list index out of range
    Press any key to continue . . .
    When I press any key,the terminal closes and nothing else happens :/
    Do any of you know how to fix this issue? Thanks in advance
    Please read recent posts above about VTM DRM.
  2. Hi xplorr, we've got a problem with downloading from VRTNU. This episode is uploaded with a different dash code or manifest LINK.
    Is it possible to fix this?
  3. Member xplorr's Avatar
    Feb 2017
    Europe
    This file had no supported downloadable formats.
    Jul 2017
    North Pole
    Hi Xplorr..
    Nice to see you are still active here ...
    You could add the command "--list-formats" in your GUI, which would then open eg. another window showing the user exactly all available downloadable video+audio formats of the given URL video ...
    HTML Code:
    [HTML]
    Video Format Options:
    -f, --format FORMAT              Video format code, see the "FORMAT
                                     SELECTION" for all the info
    --all-formats                    Download all available video formats
    --prefer-free-formats            Prefer free video formats unless a specific
                                     one is requested
    -F, --list-formats               List all available formats of requested
                                     videos
    [/HTML]
    Then the user just enters the format code in a box in your gui, and your downloader just uses the download syntax:
    C:\Program Files (x86)\TVDownloader>youtube-dl.exe -f format-code here video-url here.
    I have to do this by hand manually, cause your GUI unfortunately doesn't download BBC videos in 25FPS at high quality, but at 50FPS which makes the size of the video almost double, to that of 25fps.. , eventho 25fps would be available...
    In my case, the format-code youtube-dl listed and which i chose was 2040, so i typed:
    youtube-dl.exe -f 2040 https://www.bbc.co.uk/iplayer/episode/the_rest_of_the_url_here
    and it downloaded a video with audio already muxed in it..
    mp4 960x540 2040k , avc1.4D401F@1604k, 25.0fps, mp4a.40.2@320k
    [info] Available formats for b0bb6694:
    format code extension resolution note
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-1013 mp4 704x396 1013k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-1013 mp4 704x396 1013k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-1013 mp4 704x396 1013k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-1013 mp4 704x396 1013k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-1069 mp4 640x360 1069k , avc1.42C01E@ 688k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-1069 mp4 640x360 1069k , avc1.42C01E@ 688k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-1069 mp4 640x360 1069k , avc1.42C01E@ 688k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-1069 mp4 640x360 1069k , avc1.42C01E@ 688k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-1216 mp4 704x396 1216k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-1216 mp4 704x396 1216k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-1216 mp4 704x396 1216k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-1216 mp4 704x396 1216k , avc1.4D401E@ 827k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-1800 mp4 704x396 1800k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-1800 mp4 704x396 1800k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-1800 mp4 704x396 1800k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-1800 mp4 704x396 1800k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@128k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-2004 mp4 704x396 2004k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-2004 mp4 704x396 2004k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-2004 mp4 704x396 2004k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-2004 mp4 704x396 2004k , avc1.64001F@1570k, 50.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls-2040 mp4 960x540 2040k , avc1.4D401F@1604k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_akamai_uk_h ls_https-2040 mp4 960x540 2040k , avc1.4D401F@1604k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls-2040 mp4 960x540 2040k , avc1.4D401F@1604k, 25.0fps, mp4a.40.2@320k
    stream-uk-iptv_streaming_concrete_combined_hd_mf_limelight_u k_hls_https-2040 mp4 960x540 2040k , avc1.4D401F@1604k, 25.0fps, mp4a.40.2@320k
    it shouldn't be hard to add in your gui, just put it under some "advanced options" or "experimental options",
    it's not hard to use at all, after you can see the correct format-code from the list youtube-dl outputs on your screen/file ...
    Just add the feature, and add text there "Do not use this option unless you're advanced user, your download will not work if this value is wrong or left empty!" or something. :P
    edit: ofcourse, this would be then an optional feature in the "download quality" settings of your GUI, which would be turned OFF by default so it wouldn't cause problems for the average user.
    Jul 2017
    North Pole
    Most of these problems are NOT YoutubeVideoDownloader related problems, but the 3rd party youtube-dl.exe app related.
    for me, it usually helps to update youtube-dl.exe manually,to the latest version from the authors webpage,and put it in YoutubeVideoDownloader's installation
    directory, overwriting the old one.
    see here my little instructions. :P
    The again, as per this post by the author., he uses a custom compiled version of youtube-dl.exe .. but when the english tv-shows won't download for me with his custom version, i update it to the official latest version. :P
    Jul 2017
    België
    Downloading this episode of "Villa Sporza" halts after 02:11:32
    with the message
    56.3% of ~3.23GiB at 6.56Mi/s ETA 10:05
    ERROR: giving up after 10 retries
    https://www.vrt.be/vrtnu/a-z/villa-sporza/2018/villa-sporza-s2018a32/
    The video stops at the same time in Chrome, but does continue to the end in Firefox.
    Update: video continues also to the end in Chrome.
    TVDownloader (youtube-dl.exe) now gives error message
    Skipping fragment 3949...
    ERROR: giving up after 10 tries
    Skipping fragment 3950...
    (and continuing... 7011 fragments)
    Last edited by MarkDQ; 17th Jul 2018 at 05:09. Reason: update Chrome / skipping fragment
  7. Content encrypted: adobe-drm.
  8. Hi;
    I've a problem with the links on vrt.nu.
    I use this link: https://www.vrt.be/vrtnu/a-z/secrets/1/secrets-s1a41/
    result:
    [VrtNU] Logging in
    [VrtNU] Requesting a token
    [VrtNU] secrets-s1a41: Downloading webpage
    ERROR: Unable to extract title; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    Did I do something wrong?
    Thx
    Jul 2018
    Brussels
    Hi there,
    same problem since July 19th, seems to me the manifest code has disappeared (?) on VRT.nu.
    I've tried everything from reinstalling to updating youtube-dl, but no avail.
  10. Member xplorr's Avatar
    Feb 2017
    Europe
    Originally Posted by VHRaya View Post
    Hi there,
    VRTNU.be, NPO.nl, YOUTUBE.com, ... fixed in new version 1.17.1 (see first page of this thread). (VTM.be not fixed)
    Jul 2018
    Brussels
    Xplorr,
    you deserve more than one coffee, here's a huge kiss/hug and an even huger THANK YOU!
    Jul 2018
    Belgium
    xplorr first of all thx for the fix!
    Still having issue's with:
    https://www.vrt.be/vrtnu/a-z/uki/seizoen-1/uki-d20160525-sseizoen-1a18-uki-r1-a18/
    Can you guys help me on this ?
    Jul 2017
    België
    with the message
    The download goes now to the end.
    Someone has information what has changed with the latest version?
  14. Hi. How do i pause downloads in TVDownloader?
  15. Member xplorr's Avatar
    Feb 2017
    Europe
    Type Ctrl-C to interrupt the download.
    Restart by downloading the same video. It will continue where you interrupted.
    Jul 2018
    istanbul
    please support https://www.blutv.com.tr/ this streaming service
    Jul 2018
    Brussels
    Hi again,
    a new problem has popped up since yesterday:
    [VrtNU] Logging in
    [VrtNU] backroads-europe-s1a5: Downloading webpage
    WARNING: [VrtNU] backroads-europe-s1a5: Failed to parse JSON Invalid \escape: line 9 column 70 (char 269)
    [VrtNU] backroads-europe-s1a5: Downloading JSON metadata
    [Canvas] pbs-pub-4d3a748d-5a49-410a-a250-1b09f4975f72$vid-62add9eb-f2c7-40bd-abc4-657fe8599dee: Downloading JSON metadata
    [Canvas] pbs-pub-4d3a748d-5a49-410a-a250-1b09f4975f72$vid-62add9eb-f2c7-40bd-abc4-657fe8599dee: Downloading m3u8 information
    [Canvas] pbs-pub-4d3a748d-5a49-410a-a250-1b09f4975f72$vid-62add9eb-f2c7-40bd-abc4-657fe8599dee: Downloading MPD manifest
    WARNING: [Canvas] Unknown MIME type application/mp4 in DASH manifest
    [Canvas] pbs-pub-4d3a748d-5a49-410a-a250-1b09f4975f72$vid-62add9eb-f2c7-40bd-abc4-657fe8599dee: Downloading ISM manifest
    [Canvas] pbs-pub-4d3a748d-5a49-410a-a250-1b09f4975f72$vid-62add9eb-f2c7-40bd-abc4-657fe8599dee: Downloading f4m manifest
    WARNING: Unable to download f4m manifest: HTTP Error 403: Forbidden
    This happens with most of the listed programs. Forbidden?
    Xplorr, can you help out? Once more? Or has VRTnu made it impossible, like Medialaan, to download?
  18. I think I experience a similar problem.
    [VrtNU] Logging in
    [VrtNU] het-journaal-het-journaal-13u-20180810: Downloading webpage
    [VrtNU] het-journaal-het-journaal-13u-20180810: Downloading JSON metadata
    [Canvas] pbs-pub-ca3160a3-5043-424f-bf6d-d28c2fb1890e$vid-55a1d2db-d838-4bf5-bfd3-0936ccf2d4c6: Downloading JSON metadata
    [Canvas] pbs-pub-ca3160a3-5043-424f-bf6d-d28c2fb1890e$vid-55a1d2db-d838-4bf5-bfd3-0936ccf2d4c6: Downloading MPD manifest
    [Canvas] pbs-pub-ca3160a3-5043-424f-bf6d-d28c2fb1890e$vid-55a1d2db-d838-4bf5-bfd3-0936ccf2d4c6: Downloading m3u8 information
    [hlsnative] Downloading m3u8 manifest
    [hlsnative] Total fragments: 5
    [download] Destination: F:\Het journaal 13u 20180810.m3u8
    [download] 100% of 60.02KiB in 00:00
    Stays stuck this way
  19. https://www.vrt.be/vrtnu/a-z/professor-t/2/professor-t--s2a1/
    [VrtNU] professor-t--s2a1: Downloading webpage
    [VrtNU] professor-t--s2a1: Downloading JSON metadata
    [Canvas] pbs-pub-f3a2d653-94c1-4b9e-8079-73cd86ff0fd9$vid-55e7ac9b-0c79-447c-9cc1-5da3fc359cb4: Downloading JSON metadata
    [Canvas] pbs-pub-f3a2d653-94c1-4b9e-8079-73cd86ff0fd9$vid-55e7ac9b-0c79-447c-9cc1-5da3fc359cb4: Downloading m3u8 information
    WARNING: Failed to download m3u8 information: <urlopen error [Errno 11001] getaddrinfo failed>
    [Canvas] pbs-pub-f3a2d653-94c1-4b9e-8079-73cd86ff0fd9$vid-55e7ac9b-0c79-447c-9cc1-5da3fc359cb4: Downloading MPD manifest
    WARNING: Failed to download MPD manifest: <urlopen error [Errno 11001] getaddrinfo failed>
    [Canvas] pbs-pub-f3a2d653-94c1-4b9e-8079-73cd86ff0fd9$vid-55e7ac9b-0c79-447c-9cc1-5da3fc359cb4: Downloading ISM manifest
    WARNING: Failed to download ISM manifest: <urlopen error [Errno 11001] getaddrinfo failed>
    [Canvas] pbs-pub-f3a2d653-94c1-4b9e-8079-73cd86ff0fd9$vid-55e7ac9b-0c79-447c-9cc1-5da3fc359cb4: Downloading f4m manifest
    WARNING: Unable to download f4m manifest: <urlopen error [Errno 11001] getaddrinfo failed>
    ERROR: No video formats found; please report this issue on https://yt-dl.org/bug. Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
  20. https://www.citytv.com/vancouver/video/ how program dowloand video ?
  21. dear sir what about zee5.com & altbalji.com
    Yes @Petra78, charlierose.com is supported.
    Sent from my P4 using Tapatalk
  22. Member xplorr's Avatar
    Feb 2017
    Europe
    Tested it, should work
  23. Member xplorr's Avatar
    Feb 2017
    Europe
    Originally Posted by steveschumi View Post
    Can you please update the prog, i'm getting this error's now.
    tested it with this url:
    https://www.vrt.be/vrtnu/a-z/sporza--wielrennen/2018/sporza--wielrennen-d20180814-spor...ank-tour-2018/
    [Attachment 46485 - Click to enlarge]
    tThank You
  24. Member
    Aug 2018
    België
    I have a Question;
    i do download weekly the official top 40 from bbc radio one,
    since last week i can't any longer, the older shows and programs are still easy to download
  25. Member
    Jul 2017
    België
    Trying to download
    https://www.vrt.be/vrtnu/a-z/r-k--eredienst/2018/r-k--eredienst-s2018a16/
    Error Message
    ERROR: Unable to download JSON metadata: HTTP Error 404: Not Found (caused by HTTPError());
    Checking youtube-dl version:
    PS C:\program files (x86)\tvdownloader> .\youtube-dl --version
    2018.07.21-custom
    Do I need to get another youtube-dl as suggested?
    Or is it simply impossible to download this program?
  26. Or is it simply impossible to download this program?
    I have sent you PM with the downloaded file in best quality available of 5 formats.
    I just used youtube-dl & ffmpeg so this is probably not the correct thread to post the methodology and results (?)
    http://tinypic.com/r/o524q9/9
  27. Member
    Jul 2017
    België
    Many thanks for your solution!
    I understand that tvdownloader is a GUI for (modified) youtube-dl and ffmpeg, so maybe you are using other versions?
    Moreover you are using a different URL
    Where do you get this URL? It is not in the source of the url
