Getting errors on VRT.be now
DOesn't seem that big of an error but still refuses to download.
https://puu.sh/xUKd3/ce379db850.png
Results 121 to 150 of 994
Getting this error at the VTM/Vier etcetc
[Attachment 43406 - Click to enlarge] website. I'm running the prog at admin. And with the latest version. -
It has something to do with Youtube_dl. I contacted a week age Xplorr with the same problem via PM. and now it is on every website. VTM,VIER, VRT NU de video are saved as a temp file not a MP4... Or Youtube_dl is broken or has an update that we don't have or de websites have yet again updated there website...
I downloaded a series from VTM/VRT yesterday with this tool, succesfully.
So either you didn't update correctly to the newest version or something else is wrong. Not all hope is lost, have you tried with gemistdownloader? -
hi, is it possible to stop the software from also downloading the adds with videos from fox.com?
Depends on youtube-dl...
@xplorr:
it is not combining the audio with the video file on bbc videos...
still getting:
you can't fix that?HTML Code:[ffmpeg] Merging formats into "D:\[BBC]\Gardeners' World, 2017, Episode 29.mp4" ERROR: Could not write header for output file #0 (incorrect codec parameters ?): Invalid argument Press any key to continue . . .
either you have invalid parameters with ffmpeg,or you haven't defined them at all. -
Could you change the quality lines as follows so it downloads the videos as 25 FPS (25 frames per second) instead of 50 FPS ?
now I have to do it manually and write protect your HTA file so it won't get overwritten..HTML Code:<input type="radio" name="Quality" value="bestvideo[height<=1080,fps=25][ext=mp4]+bestaudio[ext=m4a]/best[height<=1080,fps=25][ext=mp4]/best[height<=1080,fps=25]">1080p
You could add an option so people could tick if they want 50/25 fps,and then add the variable,or just add it permanently as above.. -
Does YoutubeVideoDownloader work with rtmpdump, provided that it is in the same folder as youtube-dl?
Hi,
Wondering if there is any applicability for the following type example, where an html URL then in turn automatically begins playing a video . . . which has some other address that I'm not presently able to uncover ?
http://www.idahostatesman.com/entertainment/restaurants/restaurant-reviews/article178529166.html
I have an app folder that covers some 9 or 10 different video capture apps, such as VideoGet, TubeDigger, etc., and lately also equipped to run your program, as one of the options. I threw a bunch of these apps at this particular case. The only one that managed to handle this job was Fast Video Downloader. (Which might not even be mentioned in the Tools Section here on VH ?) It was kind of like a Hoover vaccuum though, gobbling up a dozen or so videos from that page indiscriminately, with some duplications for different resolution versions of the same video. And several were extraneous and irrelevant, though not differentiated by name. I had to then go through every video with a player, eliminating all but the one I had actually been after.Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com -
You're right.
Updating to the latest version of ffmpeg fixes that error.
Now it combines the video and audio file into one file.
Maybe you should update it too.
But adding mkvmerge into your tool would probably fix it permanently.
if that error=positive then use mkvmerge to mux it. -
New version 1.16 released. See first page of this thread for download.
Added option to prefer mp4/m4a demuxed video/audio (default is checked). If unchecked, other video formats may be downloaded (fi. webm, flv, ...).
Warning: merging mp4+m4a can take extra time.
Replaced ffmpeg engine with newer version.
I have done some testing with 'fps' option and I was not satisfied with the results.
At the moment I don't want to implement it. Why?
1/ I want to keep TVDownloader as simple as possible. End-users should not be bothered with "complex" decisions.
2/ There is a multitude of fps possibilities: 23.98, 23.976, 24, 25 29.97, 30, 50 59.94, 60 fps
3/ The 'fps' option did not give me the desired results (I tested o.a. on Youtube).
Even when I used <= option (with or without '?'), I could not get the desired results. Every site responds differently.
4/ You are the only one so far asking for this option: I advise you to make a custom version of TVDownloader (as you did) or use youtube-dl. ps you don't have to write-protect the modified HTA, just copy it to the program folder and run it. -
It does not have to be complex..
Add box for NTSC/PAL Framerate and then it choses between the available NTSC/PAL framerates (which you define, or add another box ADVANCED FEATURES) ..
25 (interlaced) and 50 (deinterlaced) is for Pal, 25 is the normal standard.
NTSC is 29.97 (interlaced) and 60 (deinterlaced) for the normal standard.
if one clicks for PAL or NTSC in your program, it downloads at those rates if available.
Add a box for "Interlaced ON/OFF".
The rest you can put in the advanced settings dialog, if needed.
So the program interface does stay simple.
Here's a good article about the framerates.
If I make a custom version for myself, I can share it with you (privately.. you = xplorr) to use or add in your pack for the people requiring this, if you like.
Else,you could just add the option in your setup so it will extract the version wanted to be ran, simple / with advanced settiongs, if you want to seperate
them completely.
Also on advanced settings, you can INFORM that people use them at their own "risk" that you are not responsible for what kinda results they get.
hello who managed to download video from http://www.mylifetime.com/shows/little-women-dallas/season-2/episode-10 I do not succeed with anything to go
Thank you for your wonderful tool. Is it possible to add the add the ability to login to tv provider sites - ie adobe pass auth sites. Thanks
Using TVDownloader 1.16 in combination with Windows Vista gives an error:
'The procedure entry point GetNumaNodeProcessorMaskEX could not be located in dynamic link library KERNAL32.dll'
Error is related to ffmpeg and using Windows Vista. Although it's not mentioned, ffmeg versions after June 2016 aren't anymore supporting Windows Vista and up to now it seems that it also won't be anymore in future. After installing the program TVDownloader 1.16 with ffmpeg static version 3.4.1 also added during installation, downloading of video is possible but with some error messages during download. After downloading, however audio and video files are not merged since ffmpeg is not functioning.
Solution: override older ffmeg version still compatible with ffmeg like for example ffmpeg-2.2.2, used for Audacity. Procedure:
- delete file "ffmeg.exe" in TVDownloader directory
- install older ffmpeg version by following procedure mentioned in http://adaptivesamples.com/how-to-install-ffmpeg-on-windows/. However don't use the links on the website since they point to the lastest ffmeg version but download the zip file from for example the website https://lame.buanzo.org/ffmpeg-win-2.2.2.zip. This version is compatible with TVDownloader 1.16.
Thanks for the update:
Baseline: TVDownloader on Windows Vista: replace ffmpeg with older ffmpeg-2.2.2 -
Hi. The site canaldigital.se is not yet supported by tvdownloader, any one who knows a solution to download from that site.
How to download from YouTube and other streaming sites? Thanks.
By seymoria in forum Video Streaming DownloadingReplies: 18Last Post: 12th Apr 2016, 09:43 -
Free MP3 Download Sites
By DonnAmento in forum Off topicReplies: 4Last Post: 7th Nov 2015, 07:44 -
Greetings! How to download from streaming sites?
By Dusty Bin in forum Newbie / General discussionsReplies: 5Last Post: 26th May 2013, 17:10 -
How to download videos from restricted sites
By bohori in forum Newbie / General discussionsReplies: 2Last Post: 26th May 2013, 15:44 -
Film Download Sites
By DrAlanStatham in forum Newbie / General discussionsReplies: 6Last Post: 6th Jan 2013, 15:11
