Page 25 of 34
FirstFirst ... 15 23 24 25 26 27 ... LastLast
Results 721 to 750 of 994
  1. or even better you can use addons without searching for the links everytime videodownloadhelper for chrome or the stream detector on firefox for example
  2. xx
    Last edited by maupassant; 12th Jul 2021 at 01:46. Reason: No longer a problem. Please delete my post.
  3. i have troubles with vrt nu episodes like https://www.vrt.be/vrtnu/a-z/sporza--ronde-van-frankrijk/2021/sporza--ronde-van-frankr...van-frankrijk/
    I checked for dash, mpd, changed links into the m3u8 form etc but it is not working
    Any suggestions ? thank you
  4. Code:
    yt-dlp --allow-unplayable-formats "https://ondemand-cf.lwc.vrtcdn.be/content/vod/vid-643ee7d6-0200-4dd5-8c7b-4b0a42d231bf-CDN_2/vid-643ee7d6-0200-4dd5-8c7b-4b0a42d231bf-CDN_2_drm_c904b475-2d5c-4fda-8968-99f8f947a779.ism/.mpd"
  5. Originally Posted by lomero View Post
    mp4decrypt --key 049c4eacf98102c21887c143659165b1:6d0adfad31602026dd49117f27e821ee {input} {output}
    or
    yt-dlp --hls-prefer-native "https://ondemand-cf-vrt.akamaized.net/content/vod/vid-643ee7d6-0200-4dd5-8c7b-4b0a42d231bf-CDN_2/vid-643ee7d6-0200-4dd5-8c7b-4b0a42d231bf-CDN_2_drm_c904b475-2d5c-4fda-8968-99f8f947a779_aes.ism/.m3u8"
    https://gofile.io/d/q3kYLN
        "status": "ok",
        "data": {
            "guestToken": "ajf4Iid17LAKEImwQiydgZhqfP8fDVdH",
            "downloadPage": "https://gofile.io/d/q3kYLN",
            "code": "q3kYLN",
            "parentFolder": "3c5fa5f3-f290-42c8-b840-b468d6bc1695",
            "fileId": "beeb39a9-c485-4417-80d3-205d446e197c",
            "fileName": "Rit 1.mp4",
            "md5": "d7fd83e7ffd852b7c72d9e6addce199c",
            "directLink": "https://store9.gofile.io/download/beeb39a9-c485-4417-80d3-205d446e197c/Rit%201.mp4",
            "info": "Direct links only work if your account is a donor account. Standard accounts will have their links redirected to the download page."
    discord=notaghost9997
  6. You still get keys, @notaghost?
  7. Originally Posted by lomero View Post
    I tried this and it works but i end up with 2 files (m4a and mp4)
    How can I merge them ?
    Thank you
  8. Originally Posted by help_mij View Post
    Thank you
    You should say thank you to notaghost, he already merged them for you.
    The merging is not the problem, getting the keys to decrypt them FIRST before merging, that's the problem.
    The merging is simply done with ffmpeg
    ffmpeg -i a.mp4 -i a.m4a -c copy muxed.mp4
  9. Hi,
    Next part of the current vrt.nu saga...
    Tried to downmoad this one:
    https://www.vrt.be/vrtnu/a-z/a-touch-of-frost/4/a-touch-of-frost-a2-unknown-soldiers/
    The standard way (putting the url in tvdownloader with username & password) didn't work, assets didn't work, .dash didn't work (there wasn't one ??) and .mpd was there but didn't work (as expected for international stuff).
    Anyone an idea how to solve this one ?
  10. Originally Posted by jeanjean View Post
    Hi,
    Tried to downmoad this one:https://forum.videohelp.com/images/smilies/biggrin.gif
    For international video's you change the mpd link from https://ondemand-cf.lwc.vrtcdn.be/content/vod/vid-bec16b62-e28b-47d0-bd9f-5481e0aee61d...c1b29.ism/.mpd to example >>> https://ondemand-cf.lwc.vrtcdn.be/content/vod/vid-bec16b62-e28b-47d0-bd9f-5481e0aee61d..._aes.ism/.m3u8 so for the mpd link u just add _aes.ism/.m3u8 after 29 before .ism/.mpd
  11. Again great support from ChezBompaLawijt - much appreciated !
    I should be reading the details more closely... (forgot the _aes) - shame on me.
    Great help, it works this way.
    Hi,
    Jun 2018
    Belgium
    Hi all,
    Now there's this new phenomenon with vrt.nu where Login and Password are not accepted anymore (doublechecked).
    [Attachment 59996 - Click to enlarge]
    Luckily, the direct link to the video works, but it's tedious anyhow.
    Any clues?
    Feb 2006
    Originally Posted by jschrooyen View Post
    Hi all,
    Any clues?
    try using the authenticated cookies option with youtube-dl
  14. -- username xxx and --password xxx is required on yt-dl command
    replace xxx wirh your credential
    Jun 2018
    Belgium
    That is exactly what doesn't work anymore...
    Jun 2018
    Belgium
    I presume you refer to the --cookies option with a cookie.txt file? I've tried and it makes no difference, unfortunately.
    Thanks for the suggestion, at least I've learnt something new.
  17. ok, no work for you? then write your video link
  18. Member
    Jun 2018
    Belgium
    Sure, lomero: https://www.vrt.be/vrtnu/a-z/the-planets/1/the-planets-s1a5/
    Thanks for taking care!
  19. Code:
    youtube-dl --hls-prefer-native --no-part https://ondemand-cf-vrt.akamaized.net/content/vod/vid-b17477d4-ff5a-4bb7-aff0-3fadfda1c433-CDN_4/vid-b17477d4-ff5a-4bb7-aff0-3fadfda1c433-CDN_4_drm_bd8b4649-66e1-4f55-892b-1aa8259f9787_aes.ism/.m3u8
  20. Member DB83's Avatar
    Jul 2007
    If this has been answered/addressed then apologies.
    But I am sure they worked fine in the past yet the apps*, including this one, and uptodate yt-dl, now refuse to d/l yt age-gated content. Get a message "Web page not found" and/or "Log in to confirm your age". And even when you enter your yt log in details it just generates the same or, maybe, another error.
    *I can still d/l with one paid for app but this one is more convenient.
    Jun 2018
    Belgium
    Yes indeed, lomero, that's what I meant with "the direct link to the video works". It creates a video called "m3u8.mp4" that I have to rename each time to something different in order for a subsequent download (with the same name) to succeed. I am used to downloading around 10 videos in parallel, in which each gets its own name from the site using just the link I quoted. It worked all right until a fortnight ago, that's the issue. I'm using TVDownloader 1.19a as a front end (with the latest youtube-dl) to enter my UserID and password, and for some reason, it stopped working.
    If anyone can confirm it's not me, I'd be happy.
    Thanks for trying, though.
  22. Member Seeker47's Avatar
    Jul 2005
    I'm glad that there are free, albeit techie command line solutions one can employ, which are being well discussed here. (And, granted, with the complications of possible region locks, Logins, passwords, age verifications, etc.) But personally, if I could cut out several troublesome hoops to jump through and cut to the chase with Allavsoft Downloader or TubeDigger, or Ant Downloader, then I'll all for getting the program license and simplifying my efforts. And I've done just that.
    When in Las Vegas, don't miss the Pinball Hall of Fame Museum http://www.pinballmuseum.org/ -- with over 150 tables from 6+ decades of this quintessentially American art form.
  23. Originally Posted by jschrooyen View Post
    It's the same for everyone.
    You still can download multiple videos at once by downloading them into different folders. Just change the output folder in TVDownloader with every video you try to download. You'll still have to rename them afterwards though.
  24. Member
    Jan 2021
    Argentina
    Add -o "title of the video.mp4" at end. Like this:
    youtube-dl --hls-prefer-native --no-part "https://..._aes.ism/.m3u8" -o "The planets - Aflevering 5 (Seizoen 1).mp4"
  25. Now something which has been touched before but to my knowledge still without a clear solution/workaround: downloading stuff from Goplay (former Vier).
    Using the url in TVDownloader (standard approach) doesn't work, but also the .dash or .mpd approaches don't work here (as filtering on .mpd or .dash doesn't bring any result).
    Is there any suggestion here that could help here downloading certain programs ?
    ChezBompaLawijt has been very helpful in the past, hope you - if you're not on holidays - have some ideas here as well. Would be top !
    Thanks.
  26. Just search for the m3u8 links goplay has only mpd links if a video has DRM example link >> https://stream1-vod.cdn1.sbs.prd.telenet-ops.be/geo/A_PLACE_IN_THE_SUN_SUMMER_SUN/S4/v..._F0282894.m3u8 use a extension like videodownloadhelper or HLS Downloader these can get u the links or download the videos
  27. Member xplorr's Avatar
    Feb 2017
    Europe
    Just created and uploaded new version 1.19b of TVDownloader with custom youtube-dl which fixes the VRTNU login problem.
    Enjoy and consider buying me a coffee via: PayPal Donate
    Download here: TVDownloader 1.19b
  28. Does this work with DRM-Live-Strams too?
  29. no. nothing work with DRM.
    you need found new ways...
