Page 2 of 34
FirstFirst 1 2 3 4 12 ... LastLast
Results 31 to 60 of 994
  1. ^bro need some program to download from iflix
    Jul 2017
    België
    After several tries, the download aborts with two files:
    • [name].flv.part = 30.749kB
    • [name].flv.ytdl = 1kB
    Viewing the flv.part file, it stops after 01:59
    What to do when tvdownloader aborts with a partly file?
  3. Member xplorr's Avatar
    Feb 2017
    Europe
    Sometimes it helps to retry.
    But some sites are well protected and don't allow downloading.
    Jul 2017
    North Pole
    How about adding support to download subtitles too,if available.
    Or download them automatically.
    #--write-sub Write subtitle file
    #--all-subs Download all the available subtitles of the video
    #--list-subs List all available subtitles for the video
    --all-subs
    ..and adding metadata on the video file..
    #--add-metadata Write metadata to the video file
    --add-metadata
    I had to edit and add these on the global config file since your frontend currently doesn't have the options.
    edit:
    also your GUI doesn't display correctly with my Nvidia Geforce GTX 1070 (laptop)
    with 1920x1080 resolution..
    It's missing some text in the box at the bottom..
    Thanks for the nice app.
  5. Member xplorr's Avatar
    Feb 2017
    Europe
    New version 1.7.1 available: http://bit.ly/2vM0uz4
    Jul 2017
    North Pole
    no subtitles/metadata support, nor gui display fixed.
    For people adding these manually,you have to edit a file called "youtube-dl.conf".
    #On Windows, the user wide configuration file locations are %APPDATA%\youtube-dl\config.txt
    #or C:\Users\<user name>\youtube-dl.conf.
    #Note that by default configuration file may not exist so you may need to create it yourself.
  7. Member xplorr's Avatar
    Feb 2017
    Europe
    The GUI fix is for screens with other dpi's than 96 dpi.
    And you are now able to resize or maximize the screen (ploblem exists because it's a HTA application=HTML application)
    The subtitles, I will add soon!
    Ps. what changes did you add in the youtube-dl config file?
    Jul 2017
    North Pole
    De subtitles, I will add soon!
    Just add:
    --all-subs
    for youtube-dl.exe to download all available subtitles
    and:
    --add-metadata
    for it to write the metadata (short description) on the video file.
    # Lines starting with # are comments
    #--config-location PATH Location of the configuration file; either
    # the path to the config or its containing directory.
    --all-subs
    --add-metadata
  9. Member xplorr's Avatar
    Feb 2017
    Europe
    I just released TVDownloader 1.8
    Upon request, I added option to download subtitles and write metadata to video/audio file.
    Download here: TVDownloader.zip
    Jul 2017
    North Pole
    Thank you.
  11. Thank you, xplorr, for your work. I've a problem with your program: when i press "download video" the command window opens but closes immediately.
    What's wrong? Can you help me? Thanks a lot
  12. Member xplorr's Avatar
    Feb 2017
    Europe
    Mostly it is because it cannot download the video.
    Either the website is not supported, or the url is not correct or the user and/or password of the site is not correct.
  13. My Url: https://www.bbc.co.uk/events/evjp6q/play/a566gw/b08z2x5g and my login is correct.... Maybe the Url isn't correct?
    Jul 2017
    North Pole
    The error messages it gives:
    WARNING: Could not send HEAD request to https://www.bbc.co.uk/events/evjp6q/play/a566gw/b08z2x5g: <urlopen error [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions>
    [generic] b08z2x5g: Downloading webpage
    ERROR: Unable to download webpage: <urlopen error [WinError 10013] An attempt was made to access a socket in a way forbidden by its access permissions> (caused by URLError(OSError(10013, 'An attempt was made to access a socket in a way forbidden by its access permissions', None, 10013, None),))
  15. Member xplorr's Avatar
    Feb 2017
    Europe
    Cannot fix it immediately, because of limitation in download engine. Watch out here for newer versions.
  16. Thanks a lot for your interest
  17. Landlord can do a portable version of it?
  18. Member
    Jul 2017
    North Pole
    Hi.
    The application is kinda portable.. (not fully since it does drop stuff in your current user %temp% directory,upon running..)
    It "installs" in: C:\Program Files (x86)\TVDownloader
    and when you run it,it creates a directory in the current users temp directory.. (in my case: %current_user%\AppData\Local\Temp\{CBC3F4A0-B688-4DBA-A817-D79EC4A2384B} ), where it places 3 files: coffee.png,tvdownloader.hta,tvdownloader.ico
    it then uses youtube-dl.exe and ffmpeg.exe in the directory where from tvdownloader.exe was ran from ..
    so in general,you can just copy "TVDownloader" directory from the program files wherever you like to, but remember it creates the temporary files in current user's temp directory, and when you close the application, it LEAVES them there, so you will have to delete that manually.
    It does NOT write anything into your Windows registry.
    Jul 2017
    North Pole
    @xplorr:
    Update youtube-dl.exe in your downloader to the latest version if you want BBC downloads to work,cause now they aren't.. ;P
  20. I did update, but nothing change for me. I can just read Unable and the windows did close immediately
  21. Member Seeker47's Avatar
    Jul 2005
    Hi.
    I have used this program successfully. Many thanks to xplorr.
    If he was to create a fully portable version of this, I'd like to recommend the .PAF type, as widely used at
    https://portableapps.com/
    It is surely the cleanest portable app structure I have seen, laying "all cards face up on the table" where you can see what they are, in a familiar and readily identifiable program tree, and it leaves no messy detritus behind upon exit. No temp directories with their junk. The other portable app formats I have seen mostly cannot say that. To accompany this, there should be a setting to specify where you prefer the downloads to go.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  22. Member
    Jul 2017
    North Pole
    He doesn't need to do that.
    He only needs to leave all the files in the "installer" in the same directory and run them from there (the launcher exe extracts some files in the temp directory as described in the earlier post, and that's all)
    And.. There is several good examples,even in the portableapps platform where the apps leave traces in the host machine,due to bad scripting and people (whom are making the "portables") not paying attention on the actual scripting and monitoring of the software..
  23. Member
    Jul 2017
    North Pole
    That has nothing to do with Xplorr's TVDownloader, it is a bug/limitation in youtube-dl.exe itself, I was talking about the main BBC programs, cause downloading of them
    does not work with the current version of TVDownloader,unless you update youtube-dl.exe manually...
    [debug] System config: []
    [debug] User config: ['--all-subs', '--add-metadata', '--write-description', '--write-info-json']
    [debug] Custom config: []
    [debug] Command-line args: ['--verbose', 'https://www.bbc.co.uk/events/evjp6q/play/a566gw/b08z2x5g']
    [debug] Encodings: locale cp1252, fs mbcs, out cp850, pref cp1252
    [debug] youtube-dl version 2017.07.15
    [debug] Python version 3.4.4 - Windows-10-10.0.15063
    [debug] exe versions: ffmpeg N-77704-g68eb208, ffprobe 2.2.3
    [debug] Proxy map: {}
    [bbc] b08z2x5g: Downloading webpage
    ERROR: Unable to extract playlist data; please report this issue on https://yt-dl.org/bug . Make sure you are using the latest version; type youtube-dl -U to update. Be sure to call youtube-dl with the --verbose flag and include its complete output.
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp9jcmgxq0\build\youtube_dl\YoutubeDL.py", line 776, in extract_info
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp9jcmgxq0\build\youtube_dl\extractor\comm on.py", line 433, in extract
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp9jcmgxq0\build\youtube_dl\extractor\bbc. py", line 1033, in _real_extract
    File "C:\Users\dst\AppData\Roaming\Build archive\youtube-dl\rg3\tmp9jcmgxq0\build\youtube_dl\extractor\comm on.py", line 782, in _search_regex
    youtube_dl.utils.RegexNotFoundError: Unable to extract playlist data; please report this issue on https://yt-dl.org/bug
  24. I did unterstand and I've update youtube-dl.exe in the directori where is TvDownloader, but I cannot still download. With the youtube-dl.exe up to date I've the following message:
  25. Member
    Jul 2017
    North Pole
    youtube-dl.exe can not download the videos from that web-page cause it is a bug in youtube-dl, and it is already reported on the issues.. ;P
  26. A new version of youtube-dl is out, but the bug isn't solved
  27. Member
    Jul 2017
    North Pole
  28. Member xplorr's Avatar
    Feb 2017
    Europe
    New version 1.9 released: engine replacement for vrt.be, vier.be, vijf.be, youtube.com, ...
    Download: see top of this thread.
  29. Member Seeker47's Avatar
    Jul 2005
    Not yet in the Software section here . . . .
  30. Member xplorr's Avatar
    Feb 2017
    Europe
