Page 17 of 34
FirstFirst ... 7 15 16 17 18 19 27 ... LastLast
Results 481 to 510 of 994
  1. @peasnic
    this application is GUI to yt-dl
    why thus discredit a work done by others?
    it's true this app is just parasites on youtube-dl and ffmpeg.... as are all GUIs app!
    not everyone knows how to use youtube-dl from command-line, and this offers easy settings of download options.
    and anyway, to conclude, your link it works with TVDownloader...
  2. Image
    [Attachment 52756 - Click to enlarge]
    @lomero: it doesn't work for me.
    "app" doesn't remember settings - you have to fill in user name and password all over and over again, it doesn't remember settings about quality and so on ... actually it doesn't remember anything. It is no surprise as it is "coded" in hta.
    As I said - it is just garbage
  3. very strange. i don't have nothing setting, no username and passw. only copy and paste your link on TVdownloader and work.
    try another app, or better on this simple case, use yt-dl command line. copy your link and yt-dl work.
    you have latest yt-dl? update this if don't work for you.
    if problem persist, try with VPN and use another country to bypass limit
  4. I didn't mean user name or password for this sake, but generally.
    According to that link - it doesn't work at all (for me). Obviously I have latest ytdl version. And of course - if I put it in command line with --no-cache-dir parameter, it works fluently.
    I am not saying, but author of this "app" should include this parameter in as default. Because it won't hurt anything and, as we can see, sometimes it helps.
    Link in browser works, so there are no country restrictions.
    No need any different app - I coded mine for myself, very powerfull with combination of mpv player. so I don't anything different. I just found this site when googled some knowledge about ytdl for my own app and it just drives me crazy how someone can release such an "app" which is actually for nothing. Because I don't dare to release mine, which if way more better than this.
    Peace
  5. Is possible to download Teachable courses with this tool?, I have tried, but is not working.
    Most of the videos are hosted in Wistia.
    I think the videos needs to be downloaded like a YouTube playlist. Thanks.
    Jul 2017
    North Pole
    youtube-dl CONFIGURATION.
    You can configure youtube-dl by placing any supported command line option to a configuration file. On Linux and macOS, the system wide configuration file is located at /etc/youtube-dl.conf and the user wide configuration file at ~/.config/youtube-dl/config. On Windows, the user wide configuration file locations are %APPDATA%\youtube-dl\config.txt or C:\Users\<user name>\youtube-dl.conf. Note that by default configuration file may not exist so you may need to create it yourself.
  7. Originally Posted by LZAA View Post
    Url?
    https://karen-mccall.teachable.com/courses/enrolled/394373
    You can register for free. That is the index page of the course, it would be amazing if I copy the index Url page and the program download all the videos of the course, something like downloading a YouTube playlist.
    Aug 2015
    Quebec, Canada
    Hello,
    I've downloaded TVDOWNLOADER and it works great, when it comes to video with DRM, is it possible to download the crypted file and remove the protection later ? I've read multiple pages of the thread without a clear answer. If not is there another way to do so ?
  9. Anonymous
    Guest
  10. thx for this useful tool!
    a question: how to choose also the audio quality..??
    i mean:
    in this case:
    https://www.youtube.com/watch?v=N7pZgQepXfA
    i'm able to choose the video quality best at 1080p...but the audio is only at 128kbps..how to have it at its best as the video part?
    thxs so much in adv
    cheers!
    Aug 2015
    Quebec, Canada
    @tuskacz
    Thanks for the answer.
    I guess it's also impossible to remove the DRM during the process of downloading the content ?
    Feb 2006
    i mean:
    in this case:
    thxs so much in adv
    cheers!
    for audio quality --audio-format best
    see - https://superuser.com/questions/846842/how-to-get-best-quality-audio-using-youtube-dl
  13. Anonymous
    Guest
  14. TVDownloader 1.18.4 @ modified by Ciber SLasH
    1.18.4 [ mod: 2020-05-07 ]
    Add:
    * Button "Paste" from clipboard for past "URL" and "Comment"
    * Checkbox "Write Comment" for write field "Comment" in output MP4-file
    * Save/Read parameters to/from registry "HKCU\Software\TVDownloader\"
    * Close application for press <ESC>
    1.18.4 [ mod: 2020-05-10 ]
    Add:
    * "About..." button
    * new version "youtube-dl.exe"
    Remove: some buttons & text
    Fix: optimize application code
    Jul 2017
    North Pole
    Url?
    where's the videos ?
    i only see html text documents and pdf files. :P
    you're way too lazy if you just can't click and download the pdf files manually one by one.
    when you click on it's link in the index,it pops up automatically to save the pdf file on your computer. :P
    Jul 2017
    North Pole
    i mean:
    in this case:
    thxs so much in adv
    cheers!
    HTML Code:
    [url=https://www.videohelp.com/software/youtube-dl]youtube-dl[/url].exe --list-formats [url]https://www.youtube.com/watch?v=N7pZgQepXfA[/url]
    [youtube] N7pZgQepXfA: Downloading webpage
    [info] Available formats for N7pZgQepXfA:
    format code  extension  resolution note
    249          webm       audio only tiny   48k , opus @ 50k (48000Hz), 1.80MiB
    250          webm       audio only tiny   61k , opus @ 70k (48000Hz), 2.28MiB
    251          webm       audio only tiny  109k , opus @160k (48000Hz), 4.14MiB
    140          m4a        audio only tiny  130k , m4a_dash container, mp4a.40.2@128k (44100Hz), 5.21MiB
    394          mp4        256x144    144p   93k , av01.0.00M.08, 30fps, video only, 3.20MiB
    160          mp4        256x144    144p   94k , avc1.4d400c, 30fps, video only, 2.79MiB
    278          webm       256x144    144p   99k , webm container, vp9, 30fps, video only, 3.78MiB
    133          mp4        426x240    240p  152k , avc1.4d4015, 30fps, video only, 3.76MiB
    395          mp4        426x240    240p  212k , av01.0.00M.08, 30fps, video only, 6.48MiB
    242          webm       426x240    240p  237k , vp9, 30fps, video only, 6.12MiB
    134          mp4        640x360    360p  286k , avc1.4d401e, 30fps, video only, 6.94MiB
    396          mp4        640x360    360p  374k , av01.0.01M.08, 30fps, video only, 12.45MiB
    135          mp4        854x480    480p  422k , avc1.4d401f, 30fps, video only, 10.62MiB
    243          webm       640x360    360p  435k , vp9, 30fps, video only, 11.51MiB
    397          mp4        854x480    480p  651k , av01.0.04M.08, 30fps, video only, 22.97MiB
    136          mp4        1280x720   720p  722k , avc1.4d401f, 30fps, video only, 20.53MiB
    244          webm       854x480    480p  761k , vp9, 30fps, video only, 17.84MiB
    398          mp4        1280x720   720p 1324k , av01.0.05M.08, 30fps, video only, 47.85MiB
    247          webm       1280x720   720p 1485k , vp9, 30fps, video only, 34.01MiB
    399          mp4        1920x1080  1080p 2425k , av01.0.08M.08, 30fps, video only, 88.42MiB
    248          webm       1920x1080  1080p 2673k , vp9, 30fps, video only, 99.44MiB
    137          mp4        1920x1080  1080p 3044k , avc1.640028, 30fps, video only, 98.46MiB
    22           mp4        1280x720   720p  640k , avc1.64001F, mp4a.40.2@192k (44100Hz)
    18           mp4        640x360    360p  651k , avc1.42001E, mp4a.40.2@ 96k (44100Hz), 26.19MiB (best)
    to download 1280x720 stream with audio (it's variable) in one mp4 file:
    youtube-dl.exe -f 22 https://www.youtube.com/watch?v=N7pZgQepXfA
    or if you want that 1080p stream mp4 like you already downloaded,
    youtube-dl.exe https://www.youtube.com/watch?v=N7pZgQepXfA
    that's the best audio you can have
    else you have to download the streams seperately and combine them into one file,or just use pyIDM for ease of access.
  17. Originally Posted by Ciber SLasH View Post
    TVDownloader 1.18.4 @ modified by Ciber SLasH [2020-05-06]
    great! tanxs.
    but on your zip file have:
    ffmpeg.exe
    ffprobe.exe
    TVDownloader.hta
    TVDownloader.ico
    youtube-dl.exe
    ....where is TVDownloader.exe ????
  18. Originally Posted by lomero View Post
    EXE not need. TVDownloader.exe - this pack program, that content: HTA & PNG files.
    Launch HTA-file.
  19. yes, work.
    tanxs for explanation.
  20. I got problem with the istallation on my Intel Nuc When i try to download anything i get this error.
    code execution cannot continue as MSVCR100dll cannot be found. try reinstalling the program.
    Tryed to install it again but get the same mess.
    So wonder what makes it miss that file.
  21. MSVCR100.dll is a file included in the Microsoft Visual C++ 2010 Redistributable Package.
    download and install Microsoft Visual C++ 2010 Redistributable Package
  22. Hi everybody!
    For some time now i can not download the subtitles from vrt.nu anymore with TVdownloader. At the end of the download it says "there aren't any subtitles to convert" Strange, because there are for sure subtitles on the site. For example:
    https://www.vrt.be/vrtnu/a-z/kinderen-van-de-holocaust/1/kinderen-van-de-holocaust-s1a6/
    Is there someone who knows a solution?
    Ponchovil
  23. Member xplorr's Avatar
    Feb 2017
    Europe
    New version: Version 1.18.5 30/06/2020 fix for youtube.com a.o. (new youtube-dl)
    See first page of this thread.
  24. Hello,
    Is this program good for "Live streams" capturing the m3u? Or is only for grabbing VOD?
    If you can grab the m3u, what are settings you apply to grab?
    Many thanks
  25. Member xplorr's Avatar
    Feb 2017
    Europe
    Originally Posted by Fred Flinstone View Post
    Hello,
    Many thanks
    TVDownloader was not intended for capturing m3u streams, but you can use it to capture certain streams.
    If the stream is continuous, like most are, you have to press ctrl-c to stop capturing.
    Afterwards open the .part file as a video file in f.i. VLC to view.
    I tested with an m3u8 stream.
    Ps. further processing steps will not be performed after interrupting the capture.
    Try it out and let me know if it worked for you.
  26. Member
    Jul 2017
    België
    Still on top of the TVDownloader screen (1.18.5): "Video Source URL (VRT, VTM, VIER, Youtube, Vimeo, DailyMotion, BBC, +900 more)"
    Please remove "VTM" as it is no longer possible to download from VTM (all DRM protected)
  27. Does it still work for VTM GO?
