Page 13 of 34
FirstFirst ... 3 11 12 13 14 15 23 ... LastLast
Results 361 to 390 of 994
  1. Member xplorr's Avatar
    Feb 2017
    Europe
    I released a new version 1.18.2 to fix youtube.com
    Also newest youtube-dl extractors+engine is included with custom extractors for dutch tv.
    Goto first post of this thread to download version 1.18.2
  2. pletse
    Oct 2018
    België
    Thanks!
  3. TVDownloader is great, thank you for this amzing software : i have some request please : add an option to automatically paste url adree from the clipboard, choose the quality and bitrate of audio mp3 convertion, and the possiblity to remember and save option and presets.
    Thank you
  4. Member xplorr's Avatar
    Feb 2017
    Europe
    Paste url: type CTRL+V
  5. Member Seeker47's Avatar
    Jul 2005
    Thanks ! The see-saw battle with YT changes continues . . .
    When they or IMDB or somebody else forces a commercial in first, it would be great to have that auto-detected and just tossed . . . but I don't think any of the other downloaders can discriminate in that way either, so I guess you just have to cast a wide net.
    Probably this was answered before, but it would be nice to be able to specify a default download location that sticks. It seems that I have to reset this every time.
    Looking for Rare / Obscure / Hard-to-Find Films ? Check out http://rarefilmm.com/ , and also its Requests & Discussion forum http://rarefilmm.chatango.com
  6. I keep getting a <urlopen error [Errno 11004] getaddrinfo failed> error when downloading. Started after the recent update.
  7. Member xplorr's Avatar
    Feb 2017
    Europe
    Can you specify the url please.
    Check if you use a proxy or an environment variable "http_proxy" is defined while you're not using a proxy.
    Removing the http_proxy environment variable may fix the problem.
  8. youtube-dl --no-part "https://3aa37dc0e8bb47e08042e0ebb25acb34.dlvr1.net/nosec/The_CW/399/389/30482501938/GhostWhisperer-102-MendedHearts-Vantage.m3u8"
  9. Whatever that means.
    I found a program that actually works.
  10. Member Seeker47's Avatar
    Jul 2005
    Originally Posted by bejaranoangel View Post
    If that is the feature film "The Crimes of Padre Amaro" I have heard of it. Might be available from Netflix or Amazon video if you are a subscriber to either; if not I may be able to locate some download source.
  11. Hi bejaranoangel ,
    My try :
    Firefox has blocked many popups
    Sub-titles in english
    https://openload.co/f/cLRkH6accwY/The_Crime_of_Father_Amaro_/_El_crimen_del_padre_Amaro_(2002)_DVDrip.mp4
    Cheers .
    JE SUIS CHARLIE !!!
  12. Hello,
    How can I download a list partially? For example, from video 35 to 60.
    Thanks in advance.
  13. youtube-dl --playlist-items 35-60 --no-part URL
  14. Thanks LZAA,
    Is there any way to do it with the tvdownloader application?
    My problem is that in the playlist of 119 videos have deleted the 34 and the 82. TVdownloader download correctly until 33 and then it is canceled.
    Thanks,
  15. Use what works.
  16. Thank you very much LZAA,
    It works perfectly, I had an error in the writing of the instruction, the quotes were missing in the URL
  17. Can you add please batch download for multiple format?
    Add adwanced option, in this option task.
    Example task 1: Paste multiple YT urls, select destination folder, select quality and video format, and audio.
    YT have H246 MP4 and VP8. Many TV and TV box do not have VP9 codecs.
    Tas 2 download odher urls to other folder.
    Best bach download for me in comand line is:
    youtube-dl -c --title -f 22 --batch-file trawel.txt (inside file trawel.txt i have multiple urls)
    Number 22 it is quality 1280 x 720 mp4 witch audio
    Using comand exaple Youtube-dl-gui>youtube-dl -F https://www.youtube.com/watch?v=e9btIBTiWjc
    i can see more options to download, witch 60 FPS
    If i want to batch download 1280x720 i can use comand
    youtube-dl -c --title -f 298+140 --batch-file trawel.txt (it is command to download mp4 witch h264 codec) Must select video and audio. Program will mux video and audio.
    298 it is a video only
    140 it is a audio
    You know, what you can do. Please add moge option for Yours GUI program
    Sorry for my Eng.
  18. This program is incredible, great work and thanks for sharing!
    Any chance you could add Flosports.tv and their sub sites (particularly Flograppling.com) to the supported sites? This would be very helpful to me. I've tried many ways and haven't found any way to get videos from there downloaded for offline view.
  19. Originally Posted by LZAA View Post
    Hi LZA, do you mean you need access to it or that it can't be accessed (e.g. due to DRM)?
  20. Need data for authorization.
  21. xplorr and others,
    Am a beginner but have been able to download PBS NOVA and other videos using youtube-dl-gui-0.4 port (need port because can not install apps on the Win7 PC that use to dl videos).
    Am unable to dl "Apollo's Daring Mission" https://www.pbs.org/wgbh/nova/video/apollos-daring-mission/ and do not know if it is me or the app that is causing this problem.
    Just dl TVDownloader v1.18b and tried to dl "Apollo's Daring Mission" failure.
    Please try to dl. Thanks
    If can not dl, hope someone else is interested in this video and will make available for dl somewhere.
