Hi All,
I am planing to use an RGB to CVBS encoder (ADV7343) to get 24-bit pixel bus line to above analog signal form. I am using IMX6 application processor for this task, and can someone direct me to a source where I can find timing parameters of this standard (Let's say the resolution is 720x480)?
This is an example of an entry I have in lcd file :
/* 720x480@ 57 Hz , pixel clk @ 27MHz*/
"MY-LCD", 57, 720, 480, 30000, 40, 60, 10, 10, 20, 10,
FB_SYNC_HOR_HIGH_ACT | FB_SYNC_VERT_HIGH_ACT,
FB_VMODE_NONINTERLACED,
0,},
I specifically need hback-porch, hfront-porch, vback-porch, vfront-porch, hsync-len, vsync-len timing parameters for above video standard !
Thanks in Advance
Any reason that you can't just get the information from Google? This turned up in the second hit:
Everything is provided and ready to use on http://www.analog.com/media/en/technical-documentation/data-sheets/ADV7342_7343.pdf - page 94 .
Newbie Adobe After Effects question - Video overlay timing
By Raycaster1 in forum EditingReplies: 3Last Post: 20th Apr 2016, 14:57 -
Keep video parameters when encrypt by VLC
By charlieho in forum Video ConversionReplies: 0Last Post: 2nd Jul 2015, 00:45 -
Proper VirtualDub timing settings for best video/audio sync
By premiumcapture in forum Capturing and VCRReplies: 10Last Post: 8th Aug 2014, 12:40 -
Demuxed video showing wrong timing.
By ecc in forum Video ConversionReplies: 9Last Post: 1st Feb 2014, 17:22 -
Doki Timing Guide - Creating / Timing Subtitles
By devilcoelhodog in forum SubtitleReplies: 0Last Post: 28th Jul 2013, 00:25
