Hi,
I have a vob file which is in YUV format. I need to convert it to RAW format and then back to YUV.
I need to know what are the command vsrawsource filter in avisynth would require to recognise correct format of video when i convert it back to YUV.
What do you believe is "YUV format", if not raw?
Do you mean YUV4MPEG (*.y4m) – which is almost raw YUV video, just with a header? -
For example, this script produces five frames of 320x240 YV12 colorbars:
Opened and run with this graph in GraphStudioNext (an modern version of GraphEdit):Code:ColorBars(width=320, height=240, pixel_type="YV12") Trim(0,4)
[Attachment 40474 - Click to enlarge]
Created the attached file (zipped for upload). That's the DUMP filter at the top right of the filter chain, the NULL RENDERER at the bottom right (data goes nowhere).
The raw file can be opened with:
Code:RawSource("yv12.yuv", width=320, height=240, pixel_type="YV12")
YUV/ RGB problem in Avisynth
By spiritt in forum Newbie / General discussionsReplies: 9Last Post: 6th Sep 2015, 05:31 -
I'm looking for codecs for the following raw YUV formats
By Videogamer555 in forum Video ConversionReplies: 6Last Post: 19th Aug 2014, 02:58 -
raw YUV TO AVI. The real solution is the "YUVTOOLS" software.
By Stears555 in forum Video ConversionReplies: 5Last Post: 9th Jul 2014, 07:58 -
Display of raw yuv in virtualdub
By eejaja77 in forum Video ConversionReplies: 10Last Post: 25th May 2014, 09:33 -
yuv player for raw videos
By vhelp in forum ProgrammingReplies: 4Last Post: 5th Aug 2013, 20:21
