Got a new BD player yesterday, and solved a problem with that step frame by frame did not work unless burning directly to memory drive.
So doing this it behaves like if on a DVD disc in navigating.
What is different exactly in doing this?
What I could se it was two MTS files, instead of one. One 9 MB and one 270 MB or so.
AVCHD folder was below a PRIVATE folder, or a BDMV folder between as well etc- don't remember exactly.
It's just a short test video to learn stuff, 90s long, so no need to split into many files at all.
Does one file contain navigation stuff for player, or?
Thanks.
The AVCHD spec, which is what I think you are referring to, is meant to facilitate the full consumer video experience. It does so using not just specifically formatted encodings, but metadata and a strict file & folder structure. In order to work properly, ALL those elements must be present and in their proper places.
Copy the whole file structure from the root on down.
Scott -
From Panasonic manual:
"It is not possible to play back AVCHD and MPEG2 videos which has been dragged and dropped or copied and pasted to the media"
Don't know if there are any hidden files, or if files are having a special allocation table or something - but burning direct to media everything works.
The playback worked just putting files on there - but special features like stepping by frame only worked if burned directly.
So player seem to recognize something is different.
I started using Xbox One, which I thought should work well - but abandoned that idea and got a real standalone player that also support SDHC and USB devices apart from discs like DVD or BD.
I just continue burn to media, just curious what is happening and understanding it all.
If to save many versions on disc maybe iso images might be ways to go.
Thank you for input. -
I found this:
http://forum.doom9.org/archive/index.php/t-141361.html
So maybe only difference is that memory sticks for usb or sdhc cards are fat32 with 8+3 filenames as caps.
So long file names must be renamed if moving a structure from a optical disc.
M2TS=MTS
CLPI=CPI
MPLS=MPL
MovieObject.bdmv=MOVIEOBJ.BDM
index.bdmv=INDEX.BDM
So will test if this works dragging a structure over to memory cards and just rename stuff.
Premiere Elements does not have burning to memory cards of full discs with menu and chapter navigation - so look forward to getting this to sdhc or usb.
Drag and Drop Audio and Video Demuxer
By Adithya in forum User guidesReplies: 2Last Post: 12th Dec 2017, 00:39 -
By Adithya in forum AudioReplies: 1Last Post: 23rd Mar 2016, 11:24 -
PotPlayer Drag&Drop issue...
By man0000 in forum Software PlayingReplies: 3Last Post: 4th Jan 2015, 01:25 -
DVD duplicator with drag and drop from PC?
By tomkat2010 in forum DVD & Blu-ray WritersReplies: 4Last Post: 25th Dec 2014, 10:10 -
drag & drop encoding to lossless?
By SignedupGuest in forum Video ConversionReplies: 9Last Post: 10th Sep 2012, 00:18
