I have 2 video files of an event one with good video but bad audio and another with bad video but good audio. I was able to separate video and audio from both the files. I wanted to combine the good video and good audio. There is no proper syncing as there is a 3 seconds lag in good audio. How can I sync the video with audio? I just need to start audio after 3 seconds of video being played. Is there any tutorial on this?
MKVToolNixGUI. It'll open many file formats. Open one of the files and add the second (no need to extracted the streams first in most cases), select the video and audio you want to keep, then re-multiplex as a new MKV. There's an option for setting a delay for any stream in ms (under the Timecodes tab), so you'd have to select the audio stream you're keeping in the "tracks chapters and tags" section and set it to roughly 3000 (positive or negative). If you need another output file type you'll need to use a different program, but I don't know what that might be.
Try using Audacity. Add three seconds of silence to the beginning of the track, save it off and mux it with the video.
Failing that, you will have to use an NLE (a video editor) and load the video and audio tracks in a timeline.
You can then move the audio track until you find the sync point. Examples on Youtube (search 'sync audio with video').
VirtualDub audio out of sync, other video players all in sync
By a1s2d3f4 in forum Newbie / General discussionsReplies: 7Last Post: 11th Apr 2016, 22:36 -
MKV video/audio not in sync for added audio track
By paolone67 in forum EditingReplies: 2Last Post: 1st Sep 2014, 12:21 -
fixing audio sync without changing the video/audio quality of mp4 video
By aruwin in forum AudioReplies: 3Last Post: 8th Aug 2014, 00:10 -
Need a simple tool to sync up badly out of sync audio and video
By CompVid in forum EditingReplies: 16Last Post: 26th May 2013, 07:55 -
Demux audio from ntsc video and mux with pal,audio sync problems
By luis67 in forum AudioReplies: 6Last Post: 17th Nov 2012, 05:43
