In the Adobe scheme of things, variable frame rate clips such as those shot with devices whose names starts with "i" or downloaded from YouTube (WebM) are categorized under best-left-where-found. In cases where these clips have to be included in a Premiere timeline, one is left to transcoding them with handbrake, for one, to an amenable constant frame rate before importing them. But though handbrake does it respectably (preserving AV sync), in the latest versions only two (container) formats (MP4 and MKV) are offered as output. Staxrip still offers AVI (not clear if any other codec apart from xvid is available under that), but introducing any avisynth FPS filter (convert & change; assume makes it hang) makes AV in the resulting cfr file gradually drift out of sync with each other. Short of using Vegas, is it possible to tweak handbrake or staxrip into transcoding such vfr clips into driftless cfr AVI-containered clips (using system installed VfW codecs like Ut or MagicYUV)?
For the nth time, with the possible exception of certain Intel processors, I don't have/ever owned anything whose name starts with "i".
Use AviSynth with e.g. ffms2 (adding "fpsnum" and "fpsden" parameters for vfr->cfr conversion) and then use e.g. VirtualDub or ffmpeg to encode to a lossless avi with the codec (or uncompressed) of your choice or use the avisynth virtual file system (avfs) to directly load the script in any software that can open avis.
Turning video from VFR to CFR without re-encoding?
By yetanotherlogin in forum EditingReplies: 3Last Post: 29th Aug 2016, 10:09 -
VFR to CFR
By SameSelf in forum Video ConversionReplies: 6Last Post: 7th Jun 2016, 19:46 -
RipBot264 and Handbrake producing VFR when CFR is selected
By duffbeer in forum Blu-ray RippingReplies: 9Last Post: 22nd Jan 2015, 08:50 -
Syncing VFR Video with Audio from CFR Video
By Chri5 in forum Newbie / General discussionsReplies: 11Last Post: 25th Jan 2014, 03:17 -
Converting VFR FLV (H264/AAC) to AVI (other) w/o sync issue
By kwondra34 in forum Video Streaming DownloadingReplies: 43Last Post: 11th Apr 2012, 00:54
