Hi, I just picked up a used Liteon LVW-5006 and when I try and finalize the disc it shows a "pad-lock" and won't let me finalize it. This DVD disc works fine (will finalize) on my other DVD recorder. Any help on how to get this liteon to finalize a disc would be appreciated.
David
Hi orr4sale,
A open padlock symbol on a Liteon means it's not finalized, a closed/locked padlock means it's already finalized.
Only DVD+R/RW can be used for recording with the 5006.
You also do not need to (and cannot) finalize +RWs with this model to make them compatible in other models, only the +Rs.
If you try to finalize a +RW, it will ask you to change disk.
Other brands of dvd recorders, specifically the ones that can use -RWs, do need to be finalized in that particular model to make them compatible with other players (or recorders) for playback.
Hope this helps -
I just looked at the 5006 manual and I noticed that it's a "AllWrite" recorder that can record on both -R/RWs and +R/RWs dvds. A DVD-RW recorded in the 5006 will need to be finalized to make it compatible to other players but not the DVD+RWs.
You do not need to finalize +RWs, you need to finalize +Rs, also -Rs and -RWs to make them compatible in other players.
You might not be able to finalize dvds recorded in other recorders, that's more of a hit-and-miss area, might work with some models and not with others.
Upgrade Liteon lvw-5045 to 400G successfully
By totoro168 in forum DVD & Blu-ray RecordersReplies: 237Last Post: 27th Feb 2023, 17:53 -
Copy from HDD to VCD on LiteOn LVW 5045
By johnahl in forum DVD & Blu-ray RecordersReplies: 6Last Post: 5th Aug 2013, 14:39 -
LiteOn LVW-5006 Firmware
By bevills1 in forum DVD & Blu-ray RecordersReplies: 4Last Post: 29th Jan 2013, 12:35 -
Macrovision Firmware Lite-on LVW-5006
By drewbert73 in forum DVD & Blu-ray RecordersReplies: 36Last Post: 9th Sep 2012, 12:05 -
Problem with Liteon LVW-1107HC1 DVD Recorder
By ECruz68007 in forum Newbie / General discussionsReplies: 1Last Post: 24th Jun 2012, 07:20
