I have an MP4 that in VLC for Windows (latest production version) shows the timeline at 3 hrs and 27 minutes and 4 seconds. When I Convert this to MP3, the resulting file shows a total length of 3 hrs and 26 minutes and 6 seconds. The loss of seconds appears to be spread out over the course of the entire file, not all at the end or start.
Can someone explain to me why this might happen? What is the best way to convert MP4 to MP3 and get the same timeline?
Corrupt headers and dropped packets, maybe. Try other converters/splitters, see if you get a different result.
https://www.videohelp.com/software/AoA-Audio-Extractor
https://www.videohelp.com/software/Pazera-Free-Audio-Extractor -
HD-DVD/Blu-Ray Stream Extractor. I can't remember if it opens MP4s so you might have to remux them as MKV with MKVToolNixGUI first, then extract the audio with the HD Streams Extractor, which uses eac3to for the work, which automatically tries to fix problems such as gaps in the audio.
Or MeGUI has a version of the HD Streams Extractor under the Tools menu.
VLC Media Player - keeps vibrating after converting mp4 to mp3
By eager to learn in forum Video ConversionReplies: 2Last Post: 14th Jan 2017, 11:39 -
Cannot play avi file with vlc player/divx player or GOM Media Player (GAVC)
By texasdontholdem in forum Software PlayingReplies: 11Last Post: 5th Aug 2016, 08:28 -
can't play mp4 file on vlc player
By deadman1972 in forum Software PlayingReplies: 8Last Post: 28th Oct 2013, 11:37 -
'MP4 has no usable track' yet plays in VLC Media Player
By JuliaR in forum Newbie / General discussionsReplies: 6Last Post: 10th Mar 2012, 18:57 -
Exporting MP4 with Avidemux?
By improvisation in forum Newbie / General discussionsReplies: 6Last Post: 7th Feb 2012, 10:29
