I only have a NTSC VCR. How do i know if the tape is PAL or SECAM? Image only appears during fast forward or rewind.
Results 1 to 21 of 21
For all intents & purposes, all non-NTSC tapes can be considered PAL. The pal vs. secam difference is regarding broadcast transmission.
You wouldn't be able to discern anything with an NTSC-only deck, however. And if you got a muti-standard deck, you'd still need a display that accepted pal-format signals. Only "standards-converting" players can output an NTSC signal from a PAL tape.
Scott -
Can capture device like ADVC110 capture SECAM tapes when using SECAM VCRs?
What are examples of standards converting players? -
You will not capture anything other than an NTSC tape on an NTSC VCR.
It seems from the comments that the only way to know is to get a multi system vcr which is expensive.
I think the correct term is 'Multi-Standard'. Even a PAL vcr can not playback a SECAM tape. It can handle NTSC though.
I know they cannot do a "SECAM L"(old France, East Germany) tape. Most stock PAL machines can do a ME SECAM (Middle East) tape. Not sure why though.
I have one SECAM L tape that I was looking for a machine to play it in, but later I found the straight PAL version of the tape so I gave up looking for an "L" machine.Last edited by hech54; 4th Feb 2017 at 12:07. Reason: EAST Germany, not "Eastern".
Multi standard machines can capture SECAM but in black and white only, At least mine does, the JVC HR-S7600AM S-VHS deck.
Very limited number of VCR's was capable to record SECAM, most of them transcoded SECAM as modified PAL and recorded such signal like PAL.
SECAM is fundamentally different than NTSC and PAL - it use Frequency Modulation to record Hue and Saturation signals when NTSC and PAL use Phase Modulation.
FM spectrum is way more complex. -
So I have a Panasonic NV-HD620 VCR. I'm playing back a PAL tape that started off playing ok, and now about halfway through the tape the video has gone black and white. Can I assume whoever originally recorded this tape switched formats and I am now seeing some type of SECAM signal now?
So I guess I'm SOL unless I can find a SECAM VCR...well that's a pain in the ass
I came across a YouTube video years ago discussing SECAM (L) and the very knowledgeable guy gave me a list of VCRs he knows are SECAM(or can play a tape as true SECAM):
Daewoo ST241S
Sony SLV-ED7FS
Sony SLV-SX70
THOMSON VTH7090U
PANASONIC AG-W1
HITACHI VT 598EM
SHARP VC-890ET
After scouring Ebay for about 4 years - I've never found one.... -
Not necessarily - it may be outcome that something make PAL chroma burst deviate from normal by more than color decoder is able to follow and as such decoder turn of color decoding - also chrominance level may be bellow threshold value and as such automatic gain control is unable to adjust proper level... also other thins may be involved - in VCR times digital color encoders was quite rare and also one country use usually one color system standard.
I rather suspect poor recording conditions than some tricky color system change. -
How to tell if it's pal or secam (too easy) If it's pinkish it's secam (pink on the side of the frame). What do i win ?
On an another note if you guys are looking for a french vcr (secam L) type " magnétoscope " as keyword wherever you're shopping online (ebay or else).
But if you want my advice try to buy a Pal or ntsc tape if you can...*** DIGITIZING VHS / ANALOG VIDEOS SINCE 2001**** GEAR: JVC HR-S7700MS, TOSHIBA V733EF AND MORE -
Composite Capture from VHS -- lose signal
By poncho524 in forum Capturing and VCRReplies: 3Last Post: 20th Sep 2016, 07:30 -
Can I convert a PAL B signal to PAL I ???
By irivlin in forum Video Streaming DownloadingReplies: 5Last Post: 15th May 2013, 07:03 -
SDI, Component(Y), Composite in PAL signal
By luckyo in forum Capturing and VCRReplies: 0Last Post: 18th Jun 2012, 07:22 -
Artefacts when streaming a high frequency signal through S-VHS
By mamoltub in forum Video Streaming DownloadingReplies: 5Last Post: 24th Apr 2012, 09:46 -
can a PAL disc work fine in a SECAM system ?
By Bansaw in forum Newbie / General discussionsReplies: 5Last Post: 20th Mar 2012, 04:55
