My last XP running windows XP failed. I was using TMPGEnc 3.0 to create J00_5L images for DVD Jacket_P folder, it will not run on windows 8 or 10.
I have searched for a few hours for a suitable replacement software or process and there is no obvious solution .....
If you are still making Jacket_P folders what software or what process are you following.
For those of us who still have the Sony DVP-CX995V 400 it's pretty cool to have these images when you pause the video.
Many thanks in advance
Devoir
	'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
	Ron,
 Thanks....
 I know how to make make Jackets i've been doing it for many years.... I'm trying to find out what newer software is being used to create the J00_5L files for the Jacket_P folder.
 Most of the software mentioned hasn't been updated in years or has been abandoned by it's developer. Windows 10 doesn't have the true compatibility to run the XP versions of software...
	Did you try running the program under the windows 10 compatibility mode ?? - https://support.microsoft.com/en-us/help/15078/windows-make-older-programs-compatible
	You would need to install AviSynth, then create an AviSynth script something like:
 ImageSource("yyy.jpg", end=n-1)
 Spline36Resize(v.width, v.height) # or some other resizer
 AssumeFPS(v)
 ConvertToYV12()
 or use muxman as stated here:
 http://forum.doom9.org/showthread.php?p=1381010#post1381010
 but really, is it worth it?
 As others have said, if it is worth it to you, install XP on a VM and run from there.'Do I look absolutely divine and regal, and yet at the same time very pretty and rather accessible?' - Queenie
  seeking replacement for Tsunami DVD AuthorBy ibzomie in forum Newbie / General discussionsReplies: 6Last Post: 22nd Jan 2017, 19:53
  Looking for Recommendation for Replacement DVD RecorderBy Novice20 in forum Newbie / General discussionsReplies: 17Last Post: 17th Jun 2015, 17:27
  DVD Shrink replacementBy efiste2 in forum DVD RippingReplies: 6Last Post: 20th Dec 2014, 19:08
  Replacement for Liteon ddw451s dvd recorderBy royjacob in forum Newbie / General discussionsReplies: 0Last Post: 8th Aug 2014, 12:51
  Replacement for Click to DVD Software (with Easy Cut-and-Paste) ??By acraven in forum EditingReplies: 8Last Post: 27th Jun 2012, 01:36
		 View Profile
				View Profile
			 View Forum Posts
				View Forum Posts
			 Private Message
				Private Message
