I just installed DVDStyler for the first time and experimented with it. It took some testing, but I found a way to force a first-play tittle before main menu.
To install DVDStyler in Linux Ubunto / Mint, open Terminal and paste each line one at a time hitting enter after each line. You'll need to enter password after the first line command:
Here is a screencast tutorial I made:sudo add-apt-repository ppa:ubuntuhandbook1/dvdstyler
sudo apt update
sudo apt install dvdstyler
Results 1 to 1 of 1
DvdStyler: multiple sets of menu buttons
By skaleton in forum Authoring (DVD)Replies: 16Last Post: 22nd Aug 2015, 04:09 -
Tutorial how to make animate menu in AE with motion buttons
By avid in forum Authoring (DVD)Replies: 3Last Post: 20th Feb 2014, 15:44 -
Add Dvd Main Menu to existing menu's in dvd video folder
By sasiflicker in forum Authoring (DVD)Replies: 2Last Post: 9th Nov 2013, 13:42 -
DVDstyler Chapter Menu Problem
By ProxyBlue in forum Authoring (DVD)Replies: 0Last Post: 5th Oct 2012, 23:57 -
Main menu/chapters/audio etc all on one motion menu in Encore. Possible?
By Killer3737 in forum Authoring (Blu-ray)Replies: 10Last Post: 11th Feb 2012, 13:08
