I am attempting to play an image out of my computer (macbook pro), connected to two epson projectors. When I connect the projectors to each other, they play the same image. However, I want to play the projectors side by side, to create one large image of the single source.
I'm using video as a backdrop for a play and need to spread the image across the entire wall, need 2 projectors to do that. Any advice, software, etc would be appreciated!
https://www.google.com/search?q=macbook+pro+multi+monitor
It looks like a 'docking station' is required.
http://apple.stackexchange.com/questions/117687/connect-2-external-monitors-with-macbook-pro
https://hengedocks.com/pages/vertical-macbook-pro-retina
And (I think) the mode you want is called 'extended desktop.'
https://support.apple.com/en-us/HT202351 -
I did this with a Mac Mini and a Matrox DualHead2Go, which is a portable dual-head video card. There are several versions and you have to make sure you get the right video connections for your computer and projectors.
You will also need to learn about edge blending. If you simply butt the two images up against each other, you will have a very obvious seam. So you need to overlap them with reciprocal fades, which can be done with a number of software tools. My application was for a permanent installation, so I created a hard blend in the video itself by first testing projector gamma and then doing the overlap and falloffs in the video editing app. -
Thanks, both of you. I ordered the dualheads2go. Hopefully it'll work!
I can't thank you enough. I set up my new DualHead2Go and it did exactly what I wanted it to do!
Portable Projectors Image Quality
By pixelPIC in forum Portable VideoReplies: 10Last Post: 31st Aug 2015, 13:07 -
LED Projectors: Do they last as long as they say?
By gll99 in forum DVB / IPTVReplies: 0Last Post: 4th Apr 2015, 19:47 -
VirtualDub outputting in 720x480 3:2
By Hypersonic1 in forum RestorationReplies: 5Last Post: 1st Apr 2015, 23:04 -
Why are data projectors so hard to configure?
By yetanotherlogin in forum Media Center PC / MediaCentersReplies: 7Last Post: 16th Feb 2014, 17:26 -
General questions about new digital projectors in movie theaters
By jimdagys in forum Newbie / General discussionsReplies: 4Last Post: 22nd Nov 2012, 11:41
