  1. Here are my setting I am using.
    loadplugin("E:\Programs\avisynth\mpeg2dec.dll")
    v=mpeg2source("D:\star wars ep1.d2v")
    a=wavsource("D:\star wars ep1 AC3 T01 3_2ch 448Kbps 48KHz.wav")
    audiodub(v,a)
    bicubicresize(480,360)
    addborders(0,60,0,60)
    trim(0,161289)
    #ResampleAudio(44100) # CCE 2.5 'crashfix' for Athlons
    I am ripping a dvd and making a svcd.
    It keeps freezing the program around half way through. My system is
    amd 1300 athon
    512 Ram
    what else would you need to know?
    Thanks in advance.
    localfinesse
  2. I tried it again and it froze at 76%
    Any ideas?
    localfinesse
  3. Script seems fin. plz post cce settings
  4. Here are my settings on CCE
    Thanks for all you help
    localfinesse
  5. Dont think it is going to fix your problem, but it appears by your settings you arent encoding audio..so then why the need for these lines.
    a=wavsource("D:\RatRace AC3 T01 3_2ch 448Kbps 48KHz.wav")
    audiodub(v,a)
    Or maybe the fact that you have the audio "uncheck" in CCE might be causing the problem. If you intend on doing the audio with CCE (which I would not recommend), then by what you have shown, you need to "check" Audio File and choose "PS" instead of "ES".
    I would also suggest using the 16-235 luminance, 8 DC precision, zigzag, add sequence end code, & upper field first, (if you are doing NTSC DVDs which it appeasr by your settings you are). Those are just suggestions that I feel would improve your quality, or at least give most potential for quality. They shouldnt be causing the problem, but you never know with CCE.
    76% would be just at the beginning of the 4-pass. You could try 3-pass to verify, to see if you get the same error. If so, the error should occur at ~66% of 3-pass. Hope that helps.
  6. It errors at anytime. It has done it at 11% 20% ....
    I am following this guide.
    CCE 2.5 SP DVD frameserving with Avisynth
    http://forum.vcdhelp.com/viewtopic.php?t=78221
    localfinesse
  7. Try updating your Avisynth.dll.
    That has helped alot of CCE users with freeze problems.
    Current version is 1.07d, you prolly have 1.05.
    Might help.
    - Twin -
  8. The only thing I can se that might cause your problem is you weard Mulitpass/bitrate settings. If you really want to use avg. rate at 2592, and max at 2592 then why use mulltipass? So tried either just encode it with one pass or change your settings. If it is Episode i you're encoding i would use avg at 2259 audio at 224, think that will get it on 3 cd's. Or 1540 2cd's. audio at 160.
    frotsen
