I have more than 1,000 ts files that I ripped from HDV. Could anyone tell me how to convert them to m2ts files?
I know I can use tsMuxeR to remux one by one. But I want to convert them all.
The reason for converting is that google photos recognizes m2ts files but not ts file.
Thank you.
Is the reason only the filename extension? Or is there really a difference in the file structure (e.g. M2TS with timestamp, 192 bytes per block, in contrast to 188 bytes per block without timestamp in TS) that is required by this tool?
Usually, if someone asks for "batch conversion", the first idea would be "ffmpeg". In this case, using "-mpegts_m2ts_mode 1" as additional parameter would probably help creating some more or less Blu-ray compatible structure (but I don't know if more parameters are required). -
Why don't you test it on a short sample ?
If not, the batch file in this post should work, just change the .mts to .ts in the 2nd line
https://forum.videohelp.com/threads/378187-Tsmuxer-Batch-Processing?p=2442245&viewfull=1#post2442245
Repack mkv to m2ts with tsmuxer no sound
By shag00 in forum Video ConversionReplies: 4Last Post: 3rd Jul 2015, 16:45 -
M2TS file created by tsMuxer 2.6.12 displays no subtitles – Why?
By anhlinhp4 in forum SubtitleReplies: 13Last Post: 26th Jun 2014, 23:17 -
tsMuxer and joining m2ts files
By fkasparek in forum Blu-ray RippingReplies: 13Last Post: 12th Jun 2014, 12:07 -
TSmuxer problem with m2ts Subtitle
By davidecit in forum Authoring (Blu-ray)Replies: 5Last Post: 16th Jun 2013, 19:06 -
Batch file for MP4 to M2TS converstion using AVIDEMUX and TSMUXER
By shaema in forum Video ConversionReplies: 11Last Post: 8th Sep 2012, 21:40
